how much for the brake job?
Old Feb 26, 2007 | 08:00 AM
LIL RAJA's Avatar
LIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant future
how much on avg. are you guys payign for the brake pads and rotor and about what mileage wise are you having to get this done?
raja
Old Feb 26, 2007 | 09:10 AM
TCM's Avatar
TCM
TCM is infamous around these parts
The cayenne can wear through brakes anywhere from 18k- 35k miles depending on your driving characteristics. Pads run around $170 for the front, and $170 for rear as wll I beleive. Rotos are somewhere in the $150 range. So you would be takling around $1000-1100? for parts and labour I would think. That being said, you can usually get away with jsut changing the front pads if you catch it before you hit the rotor surface with the brake sensor. Hopefully, some others can shed some more like on this as well.
Old Feb 26, 2007 | 11:19 AM
SpeedDemon's Avatar
SpeedDemon is infamous around these parts
my dealer did mine at 18790 $ 1070.00
Old Feb 26, 2007 | 12:19 PM
sullyz's Avatar
sullyz is infamous around these parts
The dealer quoted me $900 just to do the fronts!
Did them myself for way less.
Buy the Centric Premium rotors. They are identical to the factory rotors, but are black powdercoated on the hats and in the veins and look sharp. I've had a lot of success with Centric brake components.
Old Feb 26, 2007 | 01:39 PM
SpeedDemon's Avatar
yea ps that price above $1070 was front pads and rotors and sensors
Old Feb 27, 2007 | 03:21 PM
96GTS's Avatar
96GTS is infamous around these parts
Just had my front pads, rotors and sensors done last week on my 04 Cayenne S with 30K miles for $780.
Old Feb 28, 2007 | 01:35 AM
racer_65's Avatar
racer_65 is infamous around these parts
I know a mechanic who can do brakes on virtually any Japanese car. Would he be able to do the Cayenne if I supply him with the parts?
Old Feb 28, 2007 | 01:37 AM
racer_65's Avatar
Your front lasted 30K miles? Is the rear still good?
I guess I'm surprised it can last that long. It seems like everyweek I have to wash brake dust off my wheels. Something is obviously wearing off!
Old Feb 28, 2007 | 04:00 AM
TT's Avatar
TT
TT is a glorious beacon of lightTT is a glorious beacon of lightTT is a glorious beacon of lightTT is a glorious beacon of lightTT is a glorious beacon of lightTT is a glorious beacon of light
LIL RAJA, didn't you sell your Cayenne?
Old Feb 28, 2007 | 07:34 AM
LIL RAJA's Avatar
yes, to my gf's friend. she just wanted to know for the future.
So i am still assisting her with get to know process etc.
raja
Old Feb 28, 2007 | 08:54 AM
SpeedDemon's Avatar
raja
haha thats
Convenient
Old Feb 28, 2007 | 12:59 PM
96GTS's Avatar
Ya, it lasted for 30K and still have about 20% pad left, the tech said the rear is still fine.
Old Feb 28, 2007 | 01:05 PM
racer_65's Avatar
In that case, the Cayenne should have fairly reasonable running costs aside from tires. Basically, I'm hearing:
1. New front brakes at 30K intervals
2. Oil changes at 20K intervals
One would need to do this level of maintenance (at a minimum) with any car. Brake jobs on BMWs and Jags run at about the same rate (speaking from experience).
Old Jun 19, 2017 | 02:41 PM
amgen1's Avatar
amgen1 is infamous around these parts
2011 Cayenne S Brakes
A little over $2k at local dealer. Did the job myself in 2.5 hours. Used Textar pads and Centric Slotted Rotors. Cost me about $900 all in for parts. Not that hard if you have the tools. Good luck.
Old Jun 20, 2017 | 07:15 AM
JWicker's Avatar
JWicker is infamous around these parts
If you have any mechanical ability at all, this is a pretty simple job. You can buy good pads online for $250 front & back, and the sensors are cheap, so change them out. Make sure you need new rotors before changing them, you may be able to get away with just swapping pads. Should take you about 1 1/2 hours or so to do all 4.
