anyone put the Gateway 500 in yet mine is installed but
Old Mar 1, 2007 | 10:34 PM
detailersdomain's Avatar
detailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond repute
I can get the IPOD to work...it powers and charges it and everything seems fine, what is the configuration of the dip switches, and did you upgrade the firmware...
Thanks!
Old Mar 1, 2007 | 11:30 PM
ffr996's Avatar
Senior Member
ffr996 is infamous around these parts
How do you upgrade the firmware
Old Mar 1, 2007 | 11:58 PM
FFR996, I haven't done the update yet but here is the link:
http://support.dension.com/support-c...root=12&id=106
Old Mar 2, 2007 | 06:09 AM
DJB's Avatar
DJB
DJB is infamous around these parts
There is a good pictorial installation description on Rennlist Cayenne forum.
Old Mar 2, 2007 | 01:48 PM
G_A's Avatar
G_A
G_A is a glorious beacon of lightG_A is a glorious beacon of lightG_A is a glorious beacon of lightG_A is a glorious beacon of lightG_A is a glorious beacon of lightG_A is a glorious beacon of light
Configuration
You should set dip switches in position equal Cayenne. Can find in manual.
Regards,
Alex
Old Mar 2, 2007 | 02:18 PM
I was told the ones on the instructions are not right. And its seeing the CD Changer but the Cd is not working.
As for the IPOD I can't get mine to work..
Old Mar 6, 2007 | 02:48 PM
G_A's Avatar
G_A
Do you have CD Changer installed?
Hello! If you do not have cd changer - in some cases IceLink will not start work without activation, same like original CD changer should be activated with system tester in some cases.
Old Mar 6, 2007 | 03:03 PM
G_A I have the CD changer ....
Old Mar 8, 2007 | 11:28 AM
G_A's Avatar
G_A
If you set dip switches
as shown on page 2 and everything connected propertly - may be device broken, or Ipod to old, I do not know, let me chek some when I'll take Icelink once again. Cd changer works ok?
Alex.
Old Mar 8, 2007 | 01:39 PM
yes I spoke to Dension and they said unplug the CD Changer .... I'll get that done later and report ...
Old Mar 8, 2007 | 05:47 PM
kooser's Avatar
kooser is infamous around these parts
Can yo u tell me anything about the interface - how things appear on your Nav screen, do you lose function/controls ON your iPod when connected, how fast can you scroll through artists (like on an 80GB iPod full for instance)?
Thanks, just curious.
Old Mar 8, 2007 | 09:24 PM
I will give you a full report once I get the CD changer out of the loop...
The_Ruski_Driver
Oct 25, 2015 08:40 PM
MadWhip
Sep 3, 2015 02:04 PM
Senatorblutarsky
Aug 28, 2015 12:44 PM
zracer196
Cayenne 958
Aug 25, 2015 06:37 PM
