CTTS brakes bigger than CTT?
Old Mar 19, 2007 | 06:45 PM
djenders's Avatar
djenders has a spectacular aura aboutdjenders has a spectacular aura about
Turbo Power Kit Option (E-81) :
  • 500 hp - Larger intercoolers - Upgraded ECU
  • - Larger Brakes
  • Front - 6 piston w/ 2 piece 380 mm discs
  • Rear - 4 piston w/ 358 mm discs
  • Upgraded Chassis and software for the air suspension
  • The E81 Power Kit was only manufactured on 2005 Cayenne Turbos and is compared to the X50 package on a 911 Twin Turbo.
    It is a prelude to the current Cayenne Turbo S. This SUV is as close to a Cayenne Turbo S as you can get without the current $93,000+ used price tag. This E81 package was an option of $19,900. This 2005 Cayenne Turbo = 500hp and 5.3 sec from 0 - 62mph ..... the 2006 Cayenne Turbo S = 520hp and 5.2 sec from 0-62mph.
Old Mar 19, 2007 | 06:51 PM
djenders's Avatar
Here is a pic of my 2006 Turbo X50 with 23's.
Old Mar 19, 2007 | 07:28 PM
BD 997's Avatar
BD 997 is infamous around these parts
wow! which lowering system did you use?
Old Mar 19, 2007 | 07:33 PM
djenders's Avatar
I used Rinspeed.
Old Mar 19, 2007 | 08:18 PM
BD 997's Avatar
Originally Posted by djenders
I used Rinspeed.
very nice... and the Bentley GTC is not bad either
Old Mar 22, 2007 | 12:21 PM
kooser's Avatar
kooser is infamous around these parts
Originally Posted by JAY@BRANDYWINE
im not sure to how much bigger they are but both front and rear are bigger, the New Cayenne Turbo uses the same brakes as the old Turbo did.
Not exactly accurate info.
Brakes on new turbo have been "redesigned".
The difference between the disc dimaters on the old turbo, turbo S and new turbo are:
Old Turbo - Front 13.78in Rear 12.99in.
Old Turbo S - Front 14.96in. Rear 14.09
New Turbo - Front 14.49in and Rear 14.09 (both with slightly different caliper hats too supposedly)
Old Mar 22, 2007 | 12:26 PM
kooser's Avatar
So in answer to the original posters question - yes the front disc diameter on the Turbo S is .47in larger while the rears are the same size as the new Turbo.
Old Mar 22, 2007 | 05:28 PM
BD 997's Avatar
thanks for the info kooser....
Old Mar 27, 2007 | 08:08 PM
SoCal955's Avatar
SoCal955 is infamous around these parts
That thing looks awesome!! Is that the Rinspeed front valance? Do you have any more Pics?
Old Mar 27, 2007 | 09:12 PM
BD 997's Avatar
more pics please!!!
Old Mar 27, 2007 | 09:36 PM
djenders's Avatar
Yes that is Rinspeed. Let me get some more pics.
Old Mar 27, 2007 | 09:46 PM
djenders's Avatar
Old Mar 27, 2007 | 11:51 PM
SoCal955's Avatar
Love the sinister look, good taste in mods. How is the fit and finish on the Rinspeed piece? Direct bolt on or did it require body work? Fiberglass? Once again, great looking ride!!!
Old Mar 27, 2007 | 11:56 PM
djenders's Avatar
I am 110% happy with rinspeed. I amazed everyday on the tires and wheels.
I have 315/25/23. Looks like a rubbe band around a rim. Never had a blowout or bent rim.
Just put about 400lbs of stuff in the back the other day and drove about 50 miles. No problems at all. Keep 45psi in all 4 tires.
Old Mar 28, 2007 | 12:35 AM
kooser's Avatar
Complete the look with driver passenger window tinting and black tailpipes.
Bad-*** nubian beast!
