DIY Oil Change
Old Sep 1, 2007 | 01:35 AM
  #31
GoldenPEPPA's Avatar
GoldenPEPPA is infamous around these parts
Brakes and rotors are next... Mine were finished at 23k.
Old Sep 4, 2007 | 11:28 AM
  #32
pigcorn's Avatar
pigcorn is infamous around these parts
Is there a DIY for the brakes? I did the oil change on my V8 this weekend after my dealer quoted my $700 and it was super easy. I didn't even jack up the car.
Old Sep 9, 2007 | 01:57 PM
  #33
rriva's Avatar
rriva is infamous around these parts
Does anyone use Motul?
Old Jan 10, 2009 | 12:50 PM
  #34
sealinc's Avatar
Registered PM
sealinc is infamous around these parts
@sealinc ,
You are not a sponsor/vendor here on 6speedonline, so stop selling, or risk being banned 🙄
Johnny
Last edited by Johnny Hotspur GT; Feb 12, 2021 at 11:33 AM. Reason: Non sponsor selling
Old Jan 11, 2009 | 08:23 PM
  #35
blrx7r1's Avatar
blrx7r1 is infamous around these parts
I did the oil change on my 04 CS and it wasn't bad at all. The only thing shocking was the amount and velocity of the oil coming out the pan. 9 qts of synthetic gushes out quickly, make sure to have sufficient drain pan capacity.
Old Jan 11, 2009 | 10:13 PM
  #36
ATJONG's Avatar
ATJONG is infamous around these parts
anybody have DIY for replacing brake pads and rotors ???
and what are the good replacement brake pads and rotors for cayenne S ?
Thanks !!
Old Jan 13, 2009 | 01:07 AM
  #37
Vekto911's Avatar
Vekto911 is just really niceVekto911 is just really niceVekto911 is just really niceVekto911 is just really nice
Underneath plastics are the "hardest" part. The rest is common.
Old Feb 19, 2009 | 03:48 PM
  #38
qooldude's Avatar
qooldude is infamous around these parts
Oil change was easy. Looks like Golden Peppa already performed the DIY brake install. Anyone else considering changing to different (low dust) pads???
https://www.6speedonline.com/forums/...ml#post1568450
Old Jan 25, 2012 | 01:08 PM
  #39
DRYRUNNER's Avatar
DRYRUNNER is infamous around these parts
I did the brakes a few months back using a DIY from Rennlist, I believe. There was a special order Torx adapter needed if you are changing the rotor (rear?) which I ordered online from Snapon. It was easier than changing the oil. It took me 45 minutes to get the three protective covers off and another 40 minutes to put them back on. The actual oil changing took 15 minutes. German overengineering. Next time will be quicker.
Old Feb 20, 2012 | 12:24 PM
  #40
Stevie S's Avatar
Stevie S is infamous around these parts
Using a Vacuum pump can for oil changes
Has anyone used a vacuum can to suck out the oil? I have used this method on my Mercedes' and it is widely known/used in those forums. I have a 05 CTT and was wondering if this method is acceptable for Cayenne's. Essentially, you use a hand pump to create a vacuum in the oil can (about 30 pumps) then you insert a tube into the dipstick tube until it hits bottom. Release the clamp on the tube and it starts evacuating the oil. Very clean and you don't have to get under the car. Change the filter, add the new oil and you are good to go.
Old Feb 20, 2012 | 12:46 PM
  #41
cuemaster's Avatar
cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !
real car guys work on their cars.
Old Feb 22, 2012 | 04:16 PM
  #42
garukun's Avatar
garukun is infamous around these parts
That's very clever, I'd be interested to see if someone has done that.
Old Feb 23, 2012 | 03:29 PM
  #43
Stevie S's Avatar
The device is called the Topsider.
Old Feb 23, 2012 | 03:52 PM
  #44
cuemaster's Avatar
those work good^
the only pita is unsecrewing the filter and being coated with oil. that can over the
filter system is very non german and something i would expect from the big three.
otherwise do the job yourself and go out to a 200 dollar dinner.
Old Feb 23, 2012 | 05:03 PM
  #45
Stevie S's Avatar
Doesn't the oil in the filter case drain into the sump?
