Help
Old Apr 3, 2004 | 03:28 AM
jamy85's Avatar
Boobie Stars
jamy85 is infamous around these parts
Help
Occasionally when I drive my cayenne, the gear switches from automatic mode to manual mode by itself. I’m 100% sure I did not accidentally switch to manual mode. Has anyone experienced this problem?
Old Apr 3, 2004 | 06:39 AM
elise386's Avatar
elise386 is infamous around these parts
One of the unique function of the Tiptronic 6's auto mode is that you can down shift by pressing the rocker switch on the steering wheel. This enable the transmission to drive at a higher gear (better fuel economy, less engine wear). Should sudden acceleration be required, moving the shifter on the center console is not required, and you can down shift by pressing the rocker switch. At this point you have the option to continue to manual shift, alternatively, if you do not give any more input, the transmission will resume full automatic. Should you problem not be the scenario I just described, take it to the dealer.
Old Apr 3, 2004 | 09:34 AM
ffr996's Avatar
Senior Member
ffr996 is infamous around these parts
It happenes to me all the time. I hit the triptronic switches on the steering wheel by mistake. as Deetz said, just switch the shifter from automatic to manual and back to automatic, and it should be fine.
Old Apr 3, 2004 | 02:11 PM
DEETZ's Avatar
GO 6SPEED!
DEETZ is infamous around these parts
did I say that? hahaha but thats normally what I do,
Old Apr 3, 2004 | 05:27 PM
ffr996's Avatar
Senior Member
i mean jamy85, not deetz.
Old Apr 6, 2004 | 01:43 PM
Ray M's Avatar
Ray M is infamous around these parts
Jamy....heard you drive away in the Cayenne the other day. Sounded great! Is that the stock exhaust or aftermarket??
Regards,
Old Apr 6, 2004 | 02:22 PM
jamy85's Avatar
Boobie Stars
Talking
Regards,
Thanks Ray ....... It is still stock. Im planning to go aftermarket as soon Techart releases their dual tips. Should sound amazing!!!
