Protosport/Protomotive Cayenne Turbo!
Old Aug 17, 2007 | 10:26 AM
str8blst's Avatar
str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !
Hey Guys,
I've been meaning to write a review and post up some pictures but just haven't had the time. Recently I had Protosport in NJ do some upgrades to the wife's car. I had them install the following...
EVO Intake
Custom Exhaust using Magnaflow Mufflers
Protomotive Software
The primary goals for these modifications were...
Better throttle response
Throatier exhaust note
Overall sportier feel
Well after having some seat time I can say I am very impressed with the work. As usual Paul and John at Protosport were a pleasure to deal with. We decided to put custom tips on the exhaust which would match the tips on my 996TT exhaust they did a while back. The workmanship is unbelievable and the sound is great. Throaty at idle but a beast under WOT. I don't know what kind of power it's putting down now, as we have yet to dyno the car. I would "estimate" it at around 520 or so.... The way the car builds boost now is just insane. It rips to full boost so quickly and pulls so hard you would never think it was a 5000lb+ truck! I don't know how much boost it's actually hitting since the gauge only reads a maximum of .8 but I plan on putting a mechanical boost gauge in soon to have a better idea of what's actually going on.
The next modification I'm planning on doing is some sort of lowering kit. Either links or a module. Just haven't decided which since I have never ridden in a car with either.
I will try and post up some pictures this weekend when I have more time. I just wanted to let people on the boards here know about some great upgrades that are available for our Cayenne Turbos!
Old Aug 18, 2007 | 03:21 AM
w202mae's Avatar
w202mae is infamous around these parts
Congratulations, I have similar mods as you and also pegged the factory boost gauge at or beyond 0.8 bar. Truck is a beast. However, can you tell me if you get this abrupt power transition at or about 3100-3200? Mine seems to do that and after research no one really have a clear answer other than the fact some people said it's normal due to the variable cam timing switching during that rpm (hence the abrupt power transition).
Old Aug 18, 2007 | 07:52 PM
str8blst's Avatar
My car seems to be pretty smooth. However When I get it back from the shop I will see how it responds in tip mode. I will say this... In tip it is a different animal. From my short time with it thus far in Tip mode it is a much different car since you can hold the revs and really take full advantage of the cars potential.
Old Oct 1, 2007 | 10:34 PM
str8blst's Avatar
Hey Guys,
I wanted to update this thread with some photos I took this weekend. Enjoy
Old Oct 2, 2007 | 05:44 AM
Griza's Avatar
Griza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud of
Looking good Alan!! Is it dropped or just in load level?
Old Oct 2, 2007 | 07:45 AM
str8blst's Avatar
Hey Griff,
In the pictures it is in Loading level. I'm still trying to decide what to go with for the drop.... Module or links....
Old Oct 2, 2007 | 10:51 AM
Griza's Avatar
I have links that i have yet to put on, not sure if I am going to do it. I would rather have a module so I think I am going to wait and do that.
Old Oct 2, 2007 | 10:57 AM
pearlcoupeg35's Avatar
pearlcoupeg35 has a reputation beyond reputepearlcoupeg35 has a reputation beyond reputepearlcoupeg35 has a reputation beyond reputepearlcoupeg35 has a reputation beyond reputepearlcoupeg35 has a reputation beyond reputepearlcoupeg35 has a reputation beyond reputepearlcoupeg35 has a reputation beyond reputepearlcoupeg35 has a reputation beyond reputepearlcoupeg35 has a reputation beyond reputepearlcoupeg35 has a reputation beyond reputepearlcoupeg35 has a reputation beyond repute
Wow, great looking truck with even better list of power mods. I would looove to hear a sound clip/see a video of that thing!
Old Oct 2, 2007 | 11:29 AM
Subbie's Avatar
Subbie is infamous around these parts
Str8blst I have a modded 04 CTT as well. I have a question for you (or anyone else with an 04 CTT), does your transmission feel sloppie and/or idoes the shifting feel jerkie at times? I drove an 08 CTT recently and the trannie felt alot better than mine. I'm trying to see if its an 04 thing or my car.
Thanx
Old Oct 2, 2007 | 12:28 PM
str8blst's Avatar
Thanks for the compliment! I'll try and take a video this weekend for you guys!
Old Oct 2, 2007 | 12:30 PM
str8blst's Avatar
Thanx
Sounds like you need to have your ECU reflashed with the most recent update. Jerky transmissions are known to happen on these cars but the issue is usually taken care of with a new ecu flash from the dealer.
My Turbo never had the jerky transmission issue but my old 04 Cayenne V6 did. I never was able to get it worked out even after the ECU Flash. I ended up trading it in for this CTT instead...
Good Luck!
socialpro
Cayenne 958
May 18, 2016 09:58 AM
PelicanParts.com
Aug 20, 2015 03:00 PM
PelicanParts.com
Cayenne 958 Vendor Classifieds
Aug 20, 2015 02:59 PM
PelicanParts.com
Aug 20, 2015 02:57 PM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
