2011 Cayenne S same engine as GTS??
Old Nov 7, 2010 | 06:11 PM
horfun's Avatar
horfun is infamous around these parts
hi guys
i just changed my wife's hybrid order to a S yesterday at the dealer, after having not much confidence in hybrid techonology at the moment.
it says it has 400bhp and from what i remember the 958 were 385bhp. so am i right to say this engine is from GTS??? or am i wrong??
are both the GTS engines and the new 2011 cayenne s engine the same??
thanks
max
Old Nov 7, 2010 | 07:58 PM
Jace's Avatar
Jace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of light
All v8's in cayennes are the same. Just tuned differently an with the turbo, well a turbo is added.
Old Nov 7, 2010 | 11:01 PM
horfun's Avatar
hi jace
ok. thanks for the advice.
Old Nov 8, 2010 | 01:09 AM
wa1l1in's Avatar
wa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of light
the previous gen had DFI?
Old Nov 8, 2010 | 07:59 PM
horfun's Avatar
but didnt the 957 come with DFI???
Old Nov 8, 2010 | 08:06 PM
Jace's Avatar
2008 and newer
Old Nov 8, 2010 | 11:27 PM
wa1l1in's Avatar
Originally Posted by Jace
2008 and newer
so same engine as 08+ or both DFI but different engines?
Old Nov 9, 2010 | 04:57 AM
gammaman's Avatar
gammaman is infamous around these parts
GTS rated at 405 HP vs. 400 for current S, so minimal difference in tuning using the same 4.8 liter block. The other reason the GTS was quicker than the S of that generation is the shorter 4.1:1 final drive ratio.
Old Nov 10, 2010 | 07:43 PM
horfun's Avatar
gammaman
thanks for this additional info. i didnt know that GTS has a shorter final drive. but wouldnt this make the GTS have lower top end??
Old Nov 11, 2010 | 09:32 AM
gammaman's Avatar
Originally Posted by horfun
gammaman
The top end would only be lower if the engine ran out of revs. Top speed is usually drag limited, as top gear is chosen for fuel consumption and low revs while cruising. Haven't seen a full road test of the GTS so can't say for sure.
Old Nov 11, 2010 | 07:27 PM
horfun's Avatar
thanks for the info.
Jul 29, 2019 11:13 AM
o'bluetouring
Cayenne 958
Aug 24, 2015 01:17 PM
thegrillboy
Cayenne 958
Aug 22, 2015 09:24 AM
PelicanParts.com
Aug 20, 2015 02:57 PM
