View Poll Results: Do you feel vibration in the steering wheel in your 2011 Cayenne?
Yes, all the time
0%
Yes, but only at 800 and 1800 RPM's
33.33%
Yes, but only on turns
0%
Yes, on turns, but only some of the time
33.33%
No
50.00%
Multiple Choice Poll. Voters: 6. You may not vote on this poll
2011 Cayenne S-- Steering Wheel Vibration
Old Jan 30, 2011 | 08:07 PM
rome's Avatar
rome is infamous around these parts
So, with over 5,000K miles now I've been able to pin point that I feel a vibration in the steering when when the RPM's are at EXACTLY 800 and then 1800. I feel it even when I am in "Park" and depress the accelerator and hold it steady at those RPM points for a few seconds, although the vibration is more pronounced when I am in "Drive" and I do the same thing. (Try this-- Put your car in drive and move the RPM's to 800...rolling forward slowly...then keep it at 800 for 5 seconds or so... Do you notice a distinct vibrationin the steering wheel compared to the otherwise dampened feel of the wheel?
It doesn't seem to matter what gear I'm in... I feel it in all of them, except that when I am 'at speed' on the highway in 8th gear at 1800 RPMs (about 80 mph) I do not feel a vibration.
I should note that when accelerating quickly through those RPM points I feel the viration, although only briefly because the RPMs are obviously not being held at those points. I also do feel a vibration from time to time (someone described it as "crunchiness" on slow turns... For eg, I always feel it when turning into my driveway, but not necessarily on every turn... I'm thinking this is connected to the car being at the RPM points noted about for a period of time as I am making certain turns...
At least one forum member has tested their CS and has not felt this, but others have. I recall feeling a similar vibration in the steering wheel on my dealer's loaner car (when I was in for soemthing else) although I do not recall if it occurred exactly at these RPM points.
The vibration is not present at other RPM points, although
Is anyone else experiencing the same thing?
Old Jan 30, 2011 | 10:14 PM
w00tPORSCHE's Avatar
w00tPORSCHE has a reputation beyond reputew00tPORSCHE has a reputation beyond reputew00tPORSCHE has a reputation beyond reputew00tPORSCHE has a reputation beyond reputew00tPORSCHE has a reputation beyond reputew00tPORSCHE has a reputation beyond reputew00tPORSCHE has a reputation beyond reputew00tPORSCHE has a reputation beyond reputew00tPORSCHE has a reputation beyond reputew00tPORSCHE has a reputation beyond reputew00tPORSCHE has a reputation beyond repute
None so far on mine but I have only driven 400 miles since date of pick up from the dealer. Did U notice it from day 1 ?
Old Feb 1, 2011 | 10:11 PM
MZCalifornia's Avatar
MZCalifornia is infamous around these parts
None so far
I picked up my 2011 CayenneS from dealer about two weeks ago and only had 250 miles on it. It's very smooth compare with my 2006 CayenneS. I have not noticed a steering wheel vibration problem so far. My suggestion is if you believe there is problem, please contact your dealership and let them know. If they cannot confirm the problem, call Porsche North America, and ask them to put it on file for even fix it. This is very important, because if there is something went wrong later, you can show them the problem happened long time ago. (sometime, dealer wouldn't file your car's problem). I have a super bad experence with my 06 CayenneS steering wheel. But it not the vibration, it made noise when turn, and when to two dealership to fix. None can notice and none can fix.
Old Feb 2, 2011 | 09:45 AM
ccexxp1's Avatar
ccexxp1 is infamous around these parts
I have no discernable viabrations in the steering at any speeds. My build date was 8/26, wonder if they resolved that issue?
Old Feb 2, 2011 | 11:32 AM
Overdraft's Avatar
Overdraft is infamous around these parts
None here - any rev/ speed....
COBB Tuning
Jan 1, 2025 09:02 AM
Jul 29, 2019 11:13 AM
STAGGERED M3
Sep 11, 2015 12:00 AM
no1joey
Sep 2, 2015 12:32 AM
ppwchiang
Aug 20, 2015 10:28 AM
