HID Foglight conversion
Old Oct 24, 2011 | 01:32 PM
BlueLodge400's Avatar
BlueLodge400 is infamous around these parts
Turbostang,
Did you get 35W or 55W for the fog lights? and are you getting any "error" codes?
Old Oct 24, 2011 | 03:35 PM
turbostang's Avatar
turbostang has a spectacular aura aboutturbostang has a spectacular aura about
Originally Posted by BlueLodge400
Turbostang,
I have the 35w hid kit and the error code eliminators from ddmtuning.com.
Is not recommended to run 55w for the fog lights.
The heat might melt the housing.
Old Oct 24, 2011 | 04:09 PM
Thanks! I'm going to order mine today.
Old Oct 28, 2011 | 06:03 AM
turbostang's Avatar
The link below will help you access the foglights.
http://forums.rennlist.com/rennforum...1-cayenne.html
Old Oct 28, 2011 | 09:18 AM
That was going to be my next question. Thank you for the help!
The new fog lights should be in next week.
Old Oct 28, 2011 | 10:16 AM
turbostang's Avatar
Is a lot easier to swap the bulbs for the non turbo model.
Turbo model have intercooler behind the foglight. Tight fit if you have big hand, removing the wheel will be a lot easier.
Old Nov 28, 2011 | 11:22 AM
co.apel's Avatar
co.apel is infamous around these parts
Originally Posted by EasternLI
I bought one of their kits because my cayenne came with halogen headlights, I also bought the resistors to prevent errors but when I got the kit I wasnt able to install the bulbs correctly because the housing doesn't have the neccesary clip to hold the bulb in, I then tried to crazy glue the bulb in (ghetto) but when I turned them on I got a 'headlight dipped' error and one of the bulbs wouldn't come on half the time, that plus the fact that im sure that the heat from the bulbs would have melted the glue and I probably would have burned up my housing made me take the whole kit out.
Sorry to bring up an old thread, but I ordered the same exact kit as you and had the same exact problem. I too had the "error" eliminator but still get the "headlight dipped" problem. It happens when I have the headlight mode on AUTO, and it is starting to get dark (early evening). If it is fully dark and on auto mode, it turns on without a problem.
It is a really annoying problem. I have asked a buddy of mine who is really good with the HIDs and he suggested to get a CANBUS HID ballast with AC Current NOT DC. He then gave me a lengthly explanation why it needs to specifically be AC and not DC. With this ballast he said, it has built in error eliminator.
I have not tried it yet. Does anyone have any experience with this?
Old Nov 28, 2011 | 08:00 PM
C4SxM5's Avatar
C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !
How hard was it to swap out the stock hid low beams? I have several extra sets from my 911 so will likely try to reuse them. I'm assuming the headlights pop out just like they did on the 911 and everything else is about the same? Hopefully my 911 kit for the fogs will also work on the CS
Old Nov 29, 2011 | 11:13 AM
co.apel's Avatar
The actual installation was really simple. Just remove entire headlight housing using the tool supplied in trunk. Then just a standard HID swap, which is a piece of cake.
If possible, I would try using CANBUS AC ballast to see if they are error free. The ddmtuning ones I got were slim ballast, DC, non-canbus and are not 100% perfect.
Old Jan 2, 2012 | 06:26 PM
C4SxM5's Avatar
I wouldnt need anything else other than the d1s bulbs if my cayenne already had hids from factory correct? Just wanting to changing the color a bit.
Old Jan 2, 2012 | 07:57 PM
race3's Avatar
race3 is infamous around these parts
has anyone figured out a way to turn the fog lights on AND still have the headlights in "active" mode, so they turn left / right when going around corners? It only works when the switch is in 'auto', but then you can't turn the fog lights on. weird logic.
Old Feb 10, 2012 | 02:50 PM
C4SxM5's Avatar
installed the low beams a few days ago and have gotten fault codes twice already. noticed that one of my low beams wasn't working anymore so figured i had one bad bulb but this morning turned the car on and both worked again... don't want to send them back just to get them returned because they couldn't reproduce the problem. any one have similar issues with the low beams?
Old Feb 10, 2012 | 05:00 PM
turbostang's Avatar
My 5000k DS1 bulbs I ordered from DDM tuning work perfectly.
No error code yet.
Might be a bad ballast. Trying swapping the bulb to the other side. If it happen again def a bulb / ballast problem.
Old Feb 10, 2012 | 05:17 PM
C4SxM5's Avatar
Bad factory ballast? I doubt that but well see if it goes out again.
Old Feb 14, 2012 | 03:49 PM
csufl's Avatar
csufl is infamous around these parts
Here are my 0.02. Got my HID foglight kit from XenonSupply.com. According to the website they have CANBus AC ballast which should be more stable, last longer without throwing error messages.
I have 4300K to match the factory HID headlight. When it first turn on, it will have blueish tint. After about 15 seconds, it turns more white/yellowish. Due to non-projector housing, at some angle it will look more white-ish. So far no error message, the unit is solid build. The cost of this unit is higher than the ebay units, but stuff like this connects to the whole electrical part of the car, I will not save my lunch money over this.
