Towing question
Depending on the size of your trailer, I suspect you will need one.
Check this out: http://rennsportkc.com/so-easy-a-por...oller-install/
State laws vary by trailer size and capacity. Porsche says you can tow up to 1650 pounds (trailer + load) without a brake controller. You should abide by which ever weight limit is lower. I occasionally tow up to the max 7700 pounds, but didn't want to go through the gymnastics of installing a conventional controller. The wireless Tekonsha Prodigy RF brake controller - to me - was worth the extra bucks. Plus you can easily swap the whole thing to different trailers and towing vehicles.
On a related note - I was disappointed to discover that LCA is essentially useless when you have a trailer connected.
//greg//
//greg//
socialpro
Cayenne 958
May 18, 2016 09:58 AM
sjg1138
Sep 1, 2015 12:03 PM
