"Chassis system failure" message ??
Old Jan 17, 2013 | 10:38 PM
UAEmonster's Avatar
UAEmonster is infamous around these parts
Hi guys,
I was driving my 2011 cayenne turbo on the highway tonight everything was smooth and running perfectly as usual suddenly "chassis system failure" message appeared .. I parked the car on the side of the road shut it down and turned it on again and it was gone.. I continued the journey for another 20 or 30km and it appeared again i didn't know what shall i do continue driving or stop the car but this time it took just few minutes appearing and gone again .. so i thought it might be just a calculation failure thing from the module .. But when i reached home , parked the car in the garage its there again ..
Anyone had the same problem? causes? How to fix it? and is it ok to drive the car until i take it to the dealer on Saturday ?
thanks in advance fellas
Old Jan 18, 2013 | 09:21 AM
svoshop's Avatar
svoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond repute
I'm sure you are ok to drive it until you get to the dealer. I would just assume one of the level sensors is not reading... Something along those lines. I would not worry too much about it, just annoying until it gets repaired.
Mike
Old Jan 18, 2013 | 09:41 AM
Fkim011's Avatar
Fkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant future
Air suspension might be leaking triggering that.
Could just have a malfunction sensor too.
Old Jan 27, 2013 | 01:56 AM
littodevil's Avatar
littodevil is infamous around these parts
Do you have a renntech lowering module? I'm working with Renntech on a updated module since I'm having the same issue from installing it new.. it has everything to do with the freq being different and etc... if you don't have the lowering module than ignore this post heh.
Larry
Old Aug 16, 2017 | 09:57 AM
jayi836's Avatar
jayi836 is infamous around these partsjayi836 is infamous around these parts
Any update on the cause of this fault ? its been a few years since the original post
Jul 29, 2019 11:13 AM
Michael_s
Sep 11, 2015 08:03 PM
LiquidElephant
Aug 27, 2015 06:17 PM
Sales@RSW
BMW //M
Aug 26, 2015 06:41 AM
