2013 cayenne
Old May 29, 2013 | 07:16 PM
Jeffflow's Avatar
Jeffflow is infamous around these parts
Question 2013 cayenne
hi, can anyone tell me how to remove my shift **** on my 2013 cayenne thank you jeff
Old May 29, 2013 | 08:33 PM
gnat's Avatar
gnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant future
This is how you do it for an automatic, no idea about a manual.
1. Twist the bottom barrel on the **** to unlock it. My tech did it by hand but I needed a rubber strap wrench.
2. Pull the button outward (towards the PCM). Again my tech could do it with his fingers, but I needed to use a pick to help pry it out to get a good finger hold.
3. While holding the button out, lift the **** off the selector shaft.
When reinstalling pull the button out and then slide in back on.
Should you (like me) break it (I didn't know to pull the button out), the car is still drivable by pulling the white plastic rod up and the moving the selector shaft backwards (use the aluminum shaft to shift, not the plastic bit). You'll have to pull the plastic rod to get it back in park too.
jonate24
Oct 25, 2015 11:34 AM
drspeed
Sep 19, 2015 06:20 AM
kahala997s
Sep 15, 2015 05:15 PM
kahala997s
Sep 15, 2015 09:51 AM
