Spacer Q (Promise I've Searched) w/ 21" Turbo Wheels
Old Aug 8, 2013 | 08:41 AM
robbys3m3's Avatar
robbys3m3 is infamous around these parts
Hi there,
I have a 2013 GTS with the 21" turbo wheels. Maybe I'm crazy, but I would really like the have the wheels' stance be just a touch more aggressive. On my other cars, I've always used hubcentric H&R spacers with great luck. In this case, the narrowest they make is a 15mm, which just eyeing it, I think is a little thick for my application. Do any of the vendors here have a hubcentric fitment for my application that will work well? If so, please also let me know the bolt length I will need to complete the package.
Thanks again
RM
Old Aug 8, 2013 | 10:05 AM
RAKLAW's Avatar
RAKLAW has a spectacular aura aboutRAKLAW has a spectacular aura about
Originally Posted by robbys3m3
Hi there,
Thanks again
RM
I have the factory OEM 5mm spacers on my turbo S
I believe Suncoast Porsche parts has them in stock
Old Aug 8, 2013 | 11:51 AM
robbys3m3's Avatar
Thank you very much. In your opinion, is 5mm noticeable?
Old Aug 8, 2013 | 11:55 AM
RAKLAW's Avatar
Yes..I had a 2013 CTT with 21" without the spacers and I can see the difference on my turbo S
Old Aug 8, 2013 | 12:22 PM
eliah3us's Avatar
eliah3us is infamous around these parts
Try SpeedArt..I have 10's both front and rear or you could try Tech-Art. I ordered my set directly from Speed-Art Germany. I will provide my contact there, if you want.
Old Aug 8, 2013 | 01:39 PM
HOiYA's Avatar
HOiYA is infamous around these parts
On the Suncoast site it says that the 5mm spacers aren't compatible with 21" wheels. Is that incorrect? Just making sure before ordering.
"Not compatible with the 20" RS Spyder Wheels, 21" Turbo Wheels, 21" Sport Edition Wheels, or vehicles equipped with snow chains."
Old Aug 8, 2013 | 03:40 PM
robbys3m3's Avatar
Thanks so much for all the responses...will check speed art now
Old Aug 8, 2013 | 06:04 PM
RAKLAW's Avatar
For the record my car has 21" SportEdition Painted Black with 5mm factory installed spacers, so I have no clue why Suncoast says not compatible.
You can also option them on the Confugurator
Old Aug 8, 2013 | 06:24 PM
robbys3m3's Avatar
Would love for you to post up a shot of your cayenne...sounds like an awesone example.
Also..congrats on the black edition..that is my favorite car out there
Old Aug 8, 2013 | 06:33 PM
RAKLAW's Avatar
Ok here he is
Old Aug 8, 2013 | 09:49 PM
nash's Avatar
nash is infamous around these parts
My guess about "Not compatible with the 20" RS Spyder Wheels, 21" Turbo Wheels, 21" Sport Edition Wheels, or vehicles equipped with snow chains." is that it would push the wheels too far out IF you didn't have the matching fender extensions. But if you do have the extensions (which I assume you do if you have the Turbo II wheels), then it should be fine.
But, you should probably get some clarification from Suncoast...
Old Aug 8, 2013 | 09:50 PM
robbys3m3's Avatar
Ok here he is
Looks great!
Old Aug 8, 2013 | 10:14 PM
eliah3us's Avatar
Robby, it's better if you contact Speed-Art direct. Those guys are real experts and they do know Porsches inside out better than any US dealership. Same goes to Tech-Art. If you tell them what you need and what you currently have installed and they will give you all your options and advise (if you need one). They have spacers in stock. I am not affiliated with them I've just gone directly to the Germans for the best stuff and advise. Plus you'll save some money also.
Old Aug 9, 2013 | 09:30 AM
PianoProdigy's Avatar
PianoProdigy has much to be proud ofPianoProdigy has much to be proud ofPianoProdigy has much to be proud ofPianoProdigy has much to be proud ofPianoProdigy has much to be proud ofPianoProdigy has much to be proud ofPianoProdigy has much to be proud ofPianoProdigy has much to be proud ofPianoProdigy has much to be proud ofPianoProdigy has much to be proud of
I bought spacers from http://www.maxspeed-motorsports.com/spacerbolts.html
PACKAGE #13 2 x 7mm + 2 X 18mm SPACERS WITH BOLTS PRICE $289.95 USD
I forget which size went where. This was on 21" Turbo 2 wheels on 958 Turbo but the stance was great.
Old Aug 10, 2013 | 10:18 PM
robbys3m3's Avatar
Thanks for this site! Think I'm gonna try 7mm all around.
