are there any new features in 2014 model??
Old Sep 22, 2013 | 03:06 PM
TGED's Avatar
TGED is infamous around these parts
Originally Posted by TTCarrera
Just bought these LED 5W5 replacements for the incandescent license plate bulbs.They work great and no conflict or warning light from the PCM:
http://www.ebay.com/itm/350791731654...84.m1439.l2649
Do you do a lot of night time driving? Please report back to see if they over heat
over time. Thanks.
Old Sep 23, 2013 | 10:23 AM
modifier's Avatar
modifier is infamous around these parts
LEDs give off very little heat. If you live in an area with lots of snow and freezing rain this can be a problem because LED tail lights or head lights will not melt the ice.
Old Sep 23, 2013 | 12:08 PM
TGED's Avatar
LED does not generate much heat. It is the resistors that give out lots of heat. In order to avoid error code, the whole LED bulb has to consume the equivalent of 5W power, same as the original incandescent bulb. And most of the wattage is used up by the resistors which generate a lot of heat. LEDs that are used in the interior do not need to contain resistors as there is no error code for interior lights.
Old Oct 18, 2013 | 06:09 PM
kechang's Avatar
kechang is a splendid one to beholdkechang is a splendid one to beholdkechang is a splendid one to beholdkechang is a splendid one to beholdkechang is a splendid one to beholdkechang is a splendid one to beholdkechang is a splendid one to behold
I just noticed the Diesel getting a 5 HP bump? typo maybe?
Cayenne Diesel, 245 hp diesel V6 engine, eight-speed Tiptronic S, permanent all-wheel
drive;
via the 2014 press info: http://press.porsche.com/vehicles/20...Cayenne_US.pdf
Old Oct 18, 2013 | 07:17 PM
Needsdecaf's Avatar
Needsdecaf has much to be proud ofNeedsdecaf has much to be proud ofNeedsdecaf has much to be proud ofNeedsdecaf has much to be proud ofNeedsdecaf has much to be proud ofNeedsdecaf has much to be proud ofNeedsdecaf has much to be proud ofNeedsdecaf has much to be proud of
drive;
Interesting.
Jul 29, 2019 11:13 AM
turkish1
Nov 11, 2015 09:01 PM
gulf gt
Aug 27, 2015 10:27 AM
