Replacing Steering Wheel with a heated one
Old Sep 1, 2013 | 06:30 PM
OCNYPORSCHE's Avatar
OCNYPORSCHE has a spectacular aura aboutOCNYPORSCHE has a spectacular aura aboutOCNYPORSCHE has a spectacular aura about
I just installed a new heated steering wheel on my 2013 Cayenne Diesel without a heated one.
Now I found out the hard way that there are no wires on the clockspring for the heated connector. I was wondering if anyone has changed out a clockspring on a 2011 and newer Cayenne? I am not sure if the heated wheel simply needs 12V. So if I change out the clockspring, could I simply put 12V on the connector that goes to the heated connector?
Old Sep 1, 2013 | 10:47 PM
TGED's Avatar
TGED is infamous around these parts
You probably need software reprogram for the heated steering, because when you switch on/off the heated steering, there is a message displayed on the round LCD screen.
Old Apr 29, 2014 | 02:04 PM
snp_cayenne's Avatar
snp_cayenne is a jewel in the roughsnp_cayenne is a jewel in the roughsnp_cayenne is a jewel in the roughsnp_cayenne is a jewel in the rough
Curious if you ever got this to work. It looks like getting the right clockspring might do the trick.
Old Apr 29, 2014 | 02:11 PM
TGED's Avatar
You also need the proper software for the heated steering to work. Because the switch is a momentary contact switch, not a mechanical on/off switch, as you cannot tell from the switch if the heated steering is on or off.
Old Apr 29, 2014 | 02:19 PM
That's right. I saw the coding in the PIWIS for both multifunction and for heated steering. At this point, I'm wondering if someone has done this already.
Old Jul 2, 2014 | 09:45 AM
mmdht2's Avatar
mmdht2 is infamous around these partsmmdht2 is infamous around these parts
my car does not have multifunction steering wheel, so I can just buy a steering wheel with multifunction and have the dealer code it?
Old Jul 25, 2014 | 01:24 AM
G_A's Avatar
G_A
G_A is a glorious beacon of lightG_A is a glorious beacon of lightG_A is a glorious beacon of lightG_A is a glorious beacon of lightG_A is a glorious beacon of lightG_A is a glorious beacon of light
You need codes to activate buttons, heating, cruise. Looks same like open pcm features. But still no way to obtain codes. May be features will works, may be not - who will try? Any case steering column module should be replaced if heating retrofitted.
And as I know some companies install not original heating in different cars, so if you have wires in steering wheel and free connectors in spring - you can connect heating not in original manner.
COBB Tuning
Jan 1, 2025 09:02 AM
MAcarbon
Mar 6, 2017 08:16 AM
no1joey
Sep 2, 2015 12:32 AM
pwdrhound
Aug 20, 2015 05:54 AM
MAcarbon
Aug 19, 2015 04:52 PM
