p1360 code on my 2012 cayenne s
I need help with my 2012 cayenne 4.8s.. the check engine sign came on most of the time.. on scanning it returns an error code p1360 which points to cylinder 2 shlrt circuit to earth.. I changed all the spark plugs, ignition coil, checked all connections and harness.. but the check engine sign still returns with the same code.. what else can I do.. pls help!!
Thnx in advance
Thnx in advance
As this car is a parallel import from UK. .warranty is by importer only. . Engine is kind of shaky for a v8 n idling rpm is ard 600..plugs n ignition coils r replaced. .but check engine sign w p1360 is there. .what can I do next? Thnx
arhim22
Sep 7, 2015 08:49 PM
