knocking sound on front, from low temperature
Old Feb 5, 2014 | 10:51 PM
solrac6262's Avatar
solrac6262 is a name known to allsolrac6262 is a name known to allsolrac6262 is a name known to allsolrac6262 is a name known to allsolrac6262 is a name known to allsolrac6262 is a name known to all
Hello all,
today I was in a shopping center temperature drop down to 24 so I jump in the car, I started to drive slow and this sound "knocking" comes from my tires, sounds like If I had a flat tire and also feels the same when you turn your steering wheel, so I stop, walked around and everything looks normal.. could this be the tires? I'm running 21" F*** Pirellis..or maybe something with the suspension.. any of you guys that have a similar issue?
thanks
Old Feb 6, 2014 | 11:11 AM
gnat's Avatar
gnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant future
Hard to say without a lot more information. Pull the wheel off and have a good look at it inside and out as well as the suspension, brake system, axle, etc... Have someone else drive it forward while you walk along side to see if you can more specifically identify the sound and where it is coming from.
Old Feb 6, 2014 | 11:21 AM
solrac6262's Avatar
the sound was coming from the front, I feel it on the steering wheel.. if I was going to describe it, it was like having a flat tire, I inspected the car and nothing and then I started to think that probably it was a flat spot on the tires, I'm running Pirellis and this are the worst tires I think ..
Old Feb 6, 2014 | 02:56 PM
gnat's Avatar
If the car hasn't sat for an inordinate about of time (months at least but really these days it should take a year or more) or major skid (shouldn't happen if your ABS is working correctly) then I'd be shocked if you had a flat spot. Your OP also seems to indicate that it was fine going to the shopping center and then was messed up after.
Could be that you lost a weight from your wheel. That could feel like you describe and be a sudden change (wouldn't expect any noise though).
Does it go away with speed? If not, does it stay the same or speed up appropriately?
Do you have the air suspension or steel? If it's steel, do you actually feel anything other than in the steering wheel? If it was a tire/wheel issue I'd expect to feel it elsewhere too, though I'd also expect the air system to possibly hide such things from you.
Do you have Servtronic/Power Steering Plus? If this issue is only at low speeds (below 35mph if I remember correctly) that is when that feature is engaged. Could be a fault there.
We have a similar issue to what you describe in our 996. It only happens the first time it's driven on a day where the temp is 37 degrees or colder and only when backing up to the right. God awful grinding/rubbing sound and you can feel it in the steering wheel. It's been happening since it's first winter and the dealer never found a fix for it even after replacing the entire front end of the car (except for the body/frame). Hopefully yours is easier to find and solve.
Old Feb 6, 2014 | 04:21 PM
solrac6262's Avatar
thanks for the info, I stopped by the dealer today, I told my sales person about the issue he said that it was from the AWD shifting something related to that in order to not be dragging my tires
Old Feb 6, 2014 | 04:56 PM
gnat's Avatar
Don't talk to sales guys about technical problems and don't ask the techs about build options
You're AWD system should never make any sounds/vibrations unless there is a serious problem.
Old Feb 6, 2014 | 04:57 PM
solrac6262's Avatar
yes, you are absolutely right, thanks Gnat
Old Feb 7, 2014 | 12:48 AM
93RSAmerica's Avatar
93RSAmerica is infamous around these parts
I had a similar issue when our Cayenne was in below zero temps. Spoke to a Tech who said after driving the brakes still generate heat. After parking if any moisture comes between the pads and disc they could freeze at cold temps. His belief is that what we were sensing was the brake pads breaking free from the disc. Note we were driving thru fresh snow prior to parking.
Old Feb 7, 2014 | 08:00 AM
solrac6262's Avatar
Thats a good possibilty, that day was around -25f it was pretty cold
Old Feb 7, 2014 | 02:05 PM
Renaissance.Man's Avatar
Moderator
Renaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond repute
Why would you curse your Pirelli tires; especially if you are not sure they are the cause of your concern? They make reputable tires.
Old Feb 7, 2014 | 05:19 PM
solrac6262's Avatar
You are right, I was not sure, but they are the worst noisy tires ever, I had them on my 911 and my F-150
Old Feb 7, 2014 | 06:12 PM
kechang's Avatar
kechang is a splendid one to beholdkechang is a splendid one to beholdkechang is a splendid one to beholdkechang is a splendid one to beholdkechang is a splendid one to beholdkechang is a splendid one to beholdkechang is a splendid one to behold
I second the Pirelli, I got the P zero before to put on my HRE for the BMW I had, supposedly the tires they put on Lamborghini from the factory, they were indeed the worst tires I've ever had..
super noisy, super stiff sidewalls.. then everything was stolen so it became someone else's problem
Old Feb 7, 2014 | 06:20 PM
HOiYA's Avatar
HOiYA is infamous around these parts
That is too funny.
Enemy
Nov 10, 2015 08:01 AM
gulf gt
Aug 27, 2015 10:27 AM
