How to remove rear seat?
Old Apr 26, 2014 | 11:58 PM
93RSAmerica's Avatar
93RSAmerica is infamous around these parts
Would like to remove at least one of the two rear seats for extended trips.
Seems straight forward with four bolts holding the rear seats down. Concern is the little 'Air Bag' symbol on the rear seat backs and wires underneath.
Any suggestions? Has anyone done this before?
Thanks,
Old Apr 27, 2014 | 07:04 AM
gnat's Avatar
gnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant future
Yeah its pretty straight forward to do.
You need a 10mm triple square driver.
It is possible to get it out without removing the cushion, but it's easier if you do. To remove the cushion grab the center front of it and pull up in a jerking motion. Once the front I latches it just lifts on out.
The air bag connector simply in clips. I had the car off, but the battery was still connected which is technically not what you are supposed to do.
There are also some clips that hold the wire to the seat frame. These were a PITA without removing the seat cushion first and I gave in and just broke them.
Remove the front bolts first, fold the back down and slide it forward, then do the rear bolts.
Old Oct 27, 2017 | 05:46 AM
smartrepair's Avatar
smartrepair is infamous around these parts
Any idea how to fool the airbag system? Removing the rear seats triggers the airbag light (which in turn makes impossible to pass MOT/inspection)
Old Oct 31, 2017 | 08:02 AM
gnat's Avatar
I know for some cars (996 is what I have read it done on) you can use resistors when replacing the steering wheel with one that has no airbag. I suppose the same concept would work here, but I don't know any more than that (e.g. what resistance is needed).
cnebrask
Oct 3, 2024 08:19 PM
r_matt_6
Oct 8, 2015 06:07 PM
STAGGERED M3
Sep 11, 2015 12:00 AM
The Oss
Aug 24, 2015 08:19 PM
saline
Aug 19, 2015 12:25 PM
