Memory seats
Memory seats
Took my 2013 C6 for car wash & now the memory seats are disabled. Wondering how I can set up the memory seats again. Misplaced my owners manual. Very difficult to find owners manual online. Thanks in advance.
It is supposed to remember your settings based on the last settings used with the key in and car on. That function doesn't work worth a damn for me though.
The manual way is to set it the way that you want, press the SET button and then press the memory slot button you want to bind it to. Slot 3 is supposed to force the current settings to the key.
Then when you get in if it doesn't reset correctly for you, press the slot button to return to your settings.
Given that you said this happened after a car wash, I'd check your fuses (you'll have to find the manual or someone else will have to chime in for which fuse(s) are relevant) to see if one popped. If it did that suggests that water is getting somewhere that it shouldn't. Unless you've put crazy mileage on it you should still be under warranty so have a dealer look into it for you.
Hey, I know how it feels when you get tired of the same platforms and nothing really stands out anymore. I was in that situation recently and just started looking around for something different. That’s when I came across Betinia Casino https://betinia-casino.pro/. I didn’t expect much at first, just wanted to explore a bit. After trying a few games and getting a feel for it, I eventually hit a pretty solid win that made the whole session worth it. From what I’ve seen, there’s a big variety of games and features, so it doesn’t feel repetitive . Now I keep it as an occasional option when I want to switch things up.
So it was really helpful
Dr Chill
Oct 13, 2011 03:02 PM
