Please Help.. Techart DRLs installation problem
Old May 30, 2014 | 02:37 PM
blacksarena's Avatar
blacksarena is infamous around these parts
Post
Originally Posted by gnat
Looking at that pic I'm not sure if the resistor and wiring would be needed, just swapping the plug.
My guess is that that box that is between the plug and light probably takes care of the shorting that snp_cayenne's wiring diagram has you do if you are making the OEM TT/GTS signals act like DRLs in a bumper swap.
That's where TA needs to be involved to confirm what their wiring at that plug is. Really they should just be sending the correct part in my opinion.
And I can feel for blacksarena as my bumper swap didn't go smoothly and the seal in one of the signals was bad and forced me to have to pay to pull the whole bumper off to swap it with a replacement. I don't care if LEDs are supposed to last forever, they don't and especially not in a prime location to get hit my high speed road debris. Having to pull the whole bumper (which has some horribly flimsy clips) to swap those lights is a horrible design in my opinion.
Gnat,
Thank you for the reply, I'm glad that you could understand what I feel..With the full kits the installation supposed to be finished in few hours. However, with the parts that is missing I waited for almost a week and Techart still haven't give me an answer. Now I have to drive the car with the nonfunctional DRLs/turn signal lights.. which really bothers me.
Old May 30, 2014 | 02:47 PM
Originally Posted by Serg124
if you don't have part №1 - and you will make something instead - dont forget put resistor there as gnat did, seems that TA have one in their harness... otherwise will be error on dashboard
Serg124,
Thank you for the reply. so are you sure if I make a replacement of the circle#1 with the parts that you mention it will work? Since I'm not sure if I should replace it by myself or wait for TA to send me one(Although they are replying very slowly). I will start looking into it though, thank you
Old May 30, 2014 | 03:19 PM
bad photo, too much flash & no focus. it is 4 pin, in fact this two are same, just different manufacturer, vag one have additional outside part. such plugs are selling thru WURTH shops as universal.
Serg124,
Thank you for the photos. As I can see from the 2nd photo, seems like the kit that I received is missing the whole wire in the lower right corner. Wondering if it's not supposed to be included in the kit or TA just forgot it.
Old May 30, 2014 | 09:04 PM
gnat's Avatar
gnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant future
Yes, but without the wiring information from TA you run the risk of it not working or potentially damaging the light (damaging something downstream on the car is possible, but probably low risk).
With the proper information, it should just require some light soldering work.
If you want to feel not so bad about your situation, dig up my "construction damage" thread. Dropped it off in Oct, got it back in Feb or Mar...
Old May 31, 2014 | 01:58 AM
Serg124's Avatar
Serg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond repute
Serg124,
I beleive yes, you can make replacement. or just wait for TA sends you missing part.. I think they forgot. maybe you need to call them to push harder.
this is photo of 957 lights, not 958. but yellow plugs are there.
Old May 31, 2014 | 02:49 AM
Just in case Techart doesn't have an answer for me.. do you have the part# that I should purchase? And do I just plug it to the red-yellow connector and connect the other side to the car? Or I actually replace the whole harness?
Sorry for asking those stupid questions but I'm quite a newbie with those wiring/technical things.. thank you again
Old May 31, 2014 | 02:58 AM
lol thanks to you gnat I really do feel a little better..can't imagine driving my car with DRLs & front turning lights missing for months.
Actually I did the bumper conversion few months ago because I saw your bumper swap pictures, it really motivated me and I never regretted doing it
and now I can't wait to have this DRLs issues fixed..
Old May 31, 2014 | 09:22 AM
gnat's Avatar
You have two options.
The first is that you can cut off their connector and replace it with the correct one. The P/Ns for the connector and the leads with pins are in my DIY DRL thread. You'll want to get some heat shrink tubing as well to protect the solder joints.
The other option would be to leave the DRL harness intact and build an adapter to make it work. You'd still need the plug and pin wires to mate with the Cayenne and you'll also need to find the correct mating for that plug on the DRL (maybe Serg knows?). There will likely still be some soldering involved and you'll want to seal up and protect those joints.
One way or another though, you need to be standing on TA to get answers. The real answer is that they should fix the issue for you. But at a minimum you need their wiring diagram.
Old Jun 2, 2014 | 04:56 PM
Originally Posted by eliah3us
I am not sure what the issue exactly is but it took my Porsche dealer a couple of hours to get the TechArt DRLs installed on my car. No issues whatsoever. All TechArt products are supplied with fitting instructions, so if one follows them correctly should be no issues at all.
eliah3us,
before you take the Techart DRLs to the dealler for installation, did you already make the strip lights on your GTS/Turbo bumper wired up as Daytime Running lights?
wondering if there will be any extra wiring works needed or it's just a direct fit.
thank you
Old Jun 2, 2014 | 10:44 PM
eliah3us's Avatar
eliah3us is infamous around these parts
Good question, cause I had the original selling Porsche dealer to get the stip lights to work as primary DRLs. Since that was a while ago I can't remember what they did to make it work but they did. I guess I have to say that after that the TechArt DRLs were a direct fit. But hey, both jobs were done by a Porsche dealer. No questions asked. Both of those dealers did get the job done.
Old Jun 2, 2014 | 11:25 PM
so it was different dealers who did the GTS/turbo bumper and TA DRLs? Mine strip lights had already been wired up as the primary DRLs by my local auto-shop, I'm wondering if there's just one way to wire those things up. hope the TA drls will be a direct fit once I receive the missing parts..
P.S. Your dealer rocks.. I live in Santa Barbara.CA and my local dealers don't even touch the aftermarket parts
Old Jun 4, 2014 | 01:19 AM
Hi guys just let you know that Techarts sent me the missing parts and the installation went smoothly(plug&play). When I see my car with the new DRLs out from the autoshop, I knew everything was worth it. Like everybody says, "you really can't go wrong with Techarts"
Although it was lame that Techart forgot to include such a important parts in their kit, which caused me extra money for re-installation, I'm still very happy with the result.
I wish to thank you all who cared, suggested and helped. I was really worried when the installation didn't go right first time, and thanks to you guys I knew what I supposed to deal with it. I really appreciate it.
Old Jun 4, 2014 | 05:58 AM
gnat's Avatar
congrats. glad it worked out.
Old Jun 4, 2014 | 09:59 AM
Serg124's Avatar
+1
Old Jun 4, 2014 | 03:35 PM
eliah3us's Avatar
Good stuff and happy end...Most folks don't even realize that TechArt uses the same shops and factories that make OEM parts for Porsche only with a TechArt design. If you are a Porsche owner you must what TechArt does. No one comes even close to those guys...
COBB Tuning
Jan 1, 2025 09:02 AM
Mackchacha
Jul 9, 2019 11:03 AM
3WDistributing
31
Oct 27, 2017 01:26 PM
Michael_s
Sep 11, 2015 08:03 PM
Aug 21, 2015 06:34 AM
