What happened to the Turbo S????
Indeed. Same can be said for the GTS
But this is still the 958 - only a slight facelift. No mechanical changes that I know of so I figured the Turbo S would still be available. I've been designing a new Turbo so I will just go for the "regular" Turbo & add the secondary cat bypass pipes & GIAC tune.
Looks like Irish21 on another thread says the GTS and Turbo S for a late Nov build date. You'll probably want to confirm with your SA.
Rumour has it there is one in San Francisco.
For 2014 were there many options on the Turbo that are standard on the Turbo S? A reason that a loaded Turbo S wouldn't cost that much more than a loaded non S.
- PDCC
- PTV
- high gloss back exterior
- 2 tone color scheme was no charge option
Even factoring the PDCC/PTV, as I recall the step up was still hefty. On the CTT there were a few option packages where as on the CTTS everything was a la carte.
When I ordered my CTTS, the main standard options over the CTT where
- PDCC
- PTV
Heh... you really went option happy. My MY2014 CTTS is almost like yours with the exception of
My CTTS was in the ball park of your CTT in price. Forgot I had these pics from my detailer.
- soft close doors - not available on MY2014
- Side Door Proteciton Molding... $990!?!?
- The Chrono package was standard on CTTS, but I opted for a compass
- 21" 911 Turbo Wheels.. I went with black sports wheels...
- white instrument dials - cool but I passed on it
- saddle brown seat belts
- fire extinguisher - cool but I passed on it
- soo much leather!
- Online Services..... heard from others this was not worth it
Don't bother with the factory extinguisher. I ordered it as I had a minor car fire while I was looking for that car's replacement, but it's not worth it. The problem is that it appears to be a Euro spec unit and not even the dealers can replace it if needed. The bottle is an odd shape that we don't seem to have in the US, so you can't put a different bottle in its place.
If you want an extinguisher, get an after market kit with a bottle size that is easier to replace should you need.
My CTTS was in the ball park of your CTT in price. Forgot I had these pics from my detailer. Fabulous. My first choice was the black/red interior with black seat inlays, black armrests & black stitching on the red & red stitching on the black. Wife wanted the black with saddle.
- I want it more for the trim around the wheel wells. It is a rough plastic but I will have it sanded smooth and painted to match the car.
- I have the black sports wheels on my Umber Cayenne so wanted something different. My wife has the Turbo wheels on her Cayenne but they are different for 2015.
- To match the seat inlays.
- soo much leather!
- The steering column, rear view mirror, sunvisors, door handle surrounds, & extended leather interior package are ???? Depends on whether they have deviated stitching. In a car with black interior not necessary since matches interior anyway.
- Know nothing about this but only 210.00.
I got it for that reason too (as mentioned I had just had a minor fire that I was lucky half a bottle of water took care of). Even if not used you're supposed to replace extinguishers every so often, but you can't unless you want to pay through the nose for shipping a pressurized container from Europe.
It's also in a bad location being under the passenger seat. With the center console you pretty much have to get out, run around the car, and then get it (hopefully the door is unlocked). That's a lot of wasted time... (speaking of, I wonder if I could swap sides? have to look at that)
I'm all for having one in the car, I'm just suggesting that you'd be better off with a aftermarket option.
