Has anyone...
Old Sep 16, 2014 | 08:03 PM
C's Bimmer's Avatar
C's Bimmer is infamous around these parts
Has anyone...
Removed a trailer hitch on their Cayenne? I might be in the minority here, but I have no use for it and want to take it off the new GTS. I think it looks better without it. Searched, but came up empty... Any help would be greatly appreciated!
Old Sep 17, 2014 | 07:02 AM
STG991's Avatar
STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !
Hitch removal.
https://www.6speedonline.com/forums/...ckage-gts.html
Everything you need here!
Old Sep 17, 2014 | 05:51 PM
BlazinPond's Avatar
BlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud of
In addition to the thread referenced above...
As far as the hitch removal, it's easier removing... than adding IMO.
First and foremost, locate a forum member that has the 'bumper beam' laying around after installing a hitch kit.
Otherwise, you'll have to locate an OEM part from a Porsche dealer/supplier.
Next:
  • Remove the bumper, unbolt and remove the hitch
  • Add the vehicle bumper beam to the location previously occupied by the hitch
  • I would suggest leaving the wiring kit, or if you have to, just remove the 7-pin connector. I cannot think of why this should require reprogramming or needing further removal.
See the below link for adding a hitch kit...it should give you an idea of what hitch install entails.
http://www.curtmfg.com/masterlibrary..._13220_INS.PDF
I have limited experience since i added a hitch kit to my CTT.
I wish i had kept the structural beam for instances like this where a fellow 6speed'er needs the part.
Good luck and great car!
BlackHorseTurbo
Nov 12, 2012 09:19 AM
StephenTi
Aug 4, 2004 12:36 AM
