No USB AUX
Old Mar 29, 2015 | 08:41 AM
Steve560's Avatar
Steve560 is infamous around these parts
No USB AUX
I'm the happy owner of a 2012 Cayenne turbo and I"m really impressed by the car! So much fun!:-)
It comes with the Burmester sound system, USB Aux input and the latest update of the PCM. But I can not see or find the Aux selection on the panel. It shows only AM FM or CD. There is no "Aux selection" possible on the PCM setting under Media/Option etc.
What can I do to activate the Aux input? I would like to use it with my iPod.
Thanks a lot
Stefan
Old Mar 29, 2015 | 11:05 AM
White Rock's Avatar
White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !
Try the disc or cd button. That's how my 911 turbo accesses the iPod
Old Mar 29, 2015 | 08:48 PM
TGED's Avatar
TGED is infamous around these parts
Usually after you plug in an iPod, the selection will then show up on the screen.
Old Mar 29, 2015 | 11:18 PM
gnat's Avatar
gnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant future
Silly question, but you do have the USB and aux ports in the center cubby right?
If so then you should always have the AUX option available even if nothing is plugged in. If you aren't seeing it and have the port, then something is wrong with the PCM.
You'll only see the iPod or USB option if a supported device is connected. Assuming you have the option, then make sure you are using a supported device (iPhone 4 vintage or newer if I recall correctly). I forget the flash drive specs other than it needs to be formatted as FAT32.
Old Mar 30, 2015 | 01:13 AM
Steve560's Avatar
Yes, I have the USB AUX port in the center console, but the USB or iPOD option isn't visible on the screen! Is there a hidden setting, where I can activate it?
Old Mar 30, 2015 | 06:04 AM
gnat's Avatar
As I said, it's only visible when the iPod is plugged in and it has to be a supported model. Which iPod are you trying to use?
00aston
Dec 25, 2015 11:11 AM
calexand
Nov 5, 2015 01:05 PM
nephew
Sep 30, 2015 06:57 AM
Ekaplan1020
Sep 12, 2015 08:23 PM
