remote keyless system alert
Old Apr 16, 2015 | 09:29 AM
dytryn's Avatar
dytryn is infamous around these parts
Well this is scary:
http://www.networkworld.com/article/...ity_2015-04-16
Old Apr 16, 2015 | 02:29 PM
TSAF NKUF's Avatar
TSAF NKUF is infamous around these parts
Yep. My cousin got his escalade stolen like this.
Old Apr 16, 2015 | 03:37 PM
seahawks's Avatar
seahawks is infamous around these parts
Calm down. Such device CANNOT beat your car's security system within limited time once your car is locked properly. The way it "bypass" your security guard is to prevent it from being activated - the device can send out strong interference signal that can "jam" the LOCK command sending by your keyless fob. Then your car isn't locked although you think it does.
The trick to defeat such device is simple: always press the button on door handle (if equipped with keyless entry) to lock your car. You should clearly hear a locking movement from lock actuator before walking away.
The device isn't $17 but ranges $1k-2k and the range is up to 300 feet.
RallyBird
Oct 7, 2015 01:20 PM
Ferrari
Aug 24, 2015 04:35 PM
