tire pressure for 22"?
Old Apr 27, 2015 | 03:46 PM
mmdht2's Avatar
mmdht2 is infamous around these partsmmdht2 is infamous around these parts
what is the recommended psi for 22" wheels, front and back?
Old Apr 28, 2015 | 07:23 AM
ronan's Avatar
ronan has much to be proud ofronan has much to be proud ofronan has much to be proud ofronan has much to be proud ofronan has much to be proud ofronan has much to be proud ofronan has much to be proud ofronan has much to be proud of
If they are OEM then check driver's door jam. Otherwise check the tire
Old Apr 30, 2015 | 06:48 PM
powdercoatmike's Avatar
powdercoatmike has a spectacular aura aboutpowdercoatmike has a spectacular aura about
I use the 21" recommended pressures
Old May 4, 2015 | 06:23 AM
mmdht2's Avatar
thanks.
Old May 4, 2015 | 11:32 AM
MikeL's Avatar
MikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of light
I set mine through the cluster to 21" summer tires, standard load over + 100mph. i cant remember the exact psi from the top of my head (ithink the fronts are 39-41 and the rears are 42-44ish), but after you set it through the cluster, the display shows the car with the current psi, push enter/select again and click on fill info, it'll say + or - telling you how much are to fill or remove on each corner.
Old May 4, 2015 | 12:50 PM
mmdht2's Avatar
wow, that's a cool function.
Jul 29, 2019 11:13 AM
RallyBird
Oct 7, 2015 01:20 PM
horsepowerfarm
Sep 10, 2015 06:09 PM
The Oss
Aug 24, 2015 08:19 PM
