Need advise!
Old Sep 12, 2015 | 08:20 PM
cayguy0521's Avatar
cayguy0521 is infamous around these parts
Need advise!
Hi, I have a 2011 CS and it reached 40k miles now.
Since it is my first Porsche, I was surprised about the price of maintenances. I just had 40k miles maintaince and even I bought some parts from the Suncoast, I still paid $1700 dollars. Now, I have to change the tires, brake pads and rotors. The dealer quotes me $8,904.12 to do all that jobs (see below) I think I am going to order the parts from the Suncoasts to save some money and thinking about having service in local body shop. Is it necessary to have service in dealership with high labor cost?
Also, I ordered my CS in 2011 and I had trouble with trim dislocated in certain places in Interior and some of other issues. So, I asked my dealership to fix that and the dealership said "The seat is securely bolted down. It may be an issue with the back of the seat it's self. Warranty wont cover anything unless it is mechanically failed. The back button does work on the steering wheel. Warranty will not cover that unless it is fully failed. I unfortunately can not make parts fail. Warranty also does not cover the trim pieces on the interior of the car." Is anyone have an idea what I should do for this? I did not do anything wrong to my CS, but it is keep happening since I purchased car in 2011.
Perform Yearly Porsche Fuel System Service (Based on
time/mileage and or vehicle history) Caution $245.00
Perform 2 Year Brake Fluid Flush (Based on time/mileage
and or vehicle history) Caution $275.00
Perform four wheel alignment (Based on individually noted
tread depths) Caution $189.95 See AI-6
Mount and balance 4 new tires (Based on individually noted
tread depths) Caution $1,320.00
Replace rear brake pads, rotors and sensor (4 mm) Caution $1,085.00
Replace front brake pads, rotors and sensor (4 mm) Caution $1,432.00
Subtotal $4,546.95
Replace rear brake pads, rotors and sensor Fail $1,067.61
Mount and balance 4 new tires Caution $1,720.00
Perform Yearly Porsche Fuel System Service Caution $245.00
Perform 2 Year Brake Fluid Flush Caution $275.00
Subtotal $2,240.00
Totals, Taxes and Fees Cost Deferred Approved
Estimate Subtotal $8,244.56
Tax $659.56 $0.00
Estimate Total $8,904.12
Old Sep 13, 2015 | 10:06 PM
gnat's Avatar
gnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant future
That list doesn't make sense. It appears to imply you are change two full sets of brakes and tires?
First up, find a good Indy in your are that knows Porsche. Second, if you are now out of warranty, have a good discussion with the Indy about what needs to be done now, what can wait, and what just isn't needed until it shows signs of problems.
Old Sep 14, 2015 | 01:54 PM
Mathme's Avatar
Mathme is infamous around these parts
x2...you're outside of warranty. Find a good Indy shop and give them your money. Heck, even for my new one, I may take it to the local indy shop for standard maintenance.
on my 09 base, the dealer quoted me $1500-1600 to change just the front brakes. the local indy porsche shop quoted the same work for $800-900. The indy also said to wait on the brake fluid flush until brakes were done...as both were coming due and as a daily driver, it wouldn't hurt to wait another 6 months on the flush.
Old Oct 6, 2015 | 07:13 AM
cayguy0521's Avatar
Thanks for all reply. Yes I checked with indy shop and they are cheaper than the delearship! One more question about the brake sensors, I am going to order the part from the online. Should I just use the OEM pad and rotors? Do I need new brake sensors?
Old Oct 8, 2015 | 12:37 PM
cayguy0521's Avatar
Thanks House Motorsports! So, do I need new springs too?
GT333
Feb 24, 2017 12:16 AM
WEEED
Cayenne
Sep 25, 2015 10:45 PM
ss2z06
Sep 9, 2015 11:46 AM
