Adventures in Plasti-dipping
Old Apr 19, 2017 | 11:09 PM
TJtheDJ's Avatar
TJtheDJ is infamous around these parts
Found it! How hard is it to peel and replace though?
Old Apr 19, 2017 | 11:29 PM
TJtheDJ's Avatar
Found it here way cheaper after shipping. Purchased. Thank you! It seems to have a nice guide on the back for easy installation!
Old Apr 20, 2017 | 01:52 PM
TJtheDJ's Avatar
Here is a photo I found of the back of the molding...
Old Apr 21, 2017 | 12:49 AM
MikeL's Avatar
MikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of light
i used fishing line, starting at one side and working the line back and forth to cut the double sided tape. occasionally, ull hit one of those nipples and have to pull and work your way behind it. wear gloves or the line can cut you. also get some goo gone, you'll have some leftover tape you'll want to remove before putting the new one back on. easy to install, removing all the left over tape is probably the most time consuming part.
Old Apr 21, 2017 | 09:01 AM
TJtheDJ's Avatar
Thank You
Hey Mike,
Thank you for the instructions! I really appreciate it! Fishing line ordered!!
TJ
Old Apr 27, 2017 | 03:57 PM
quickster2's Avatar
quickster2 is infamous around these parts
Braided line works best but it will cut you be careful wear leather gloves Kevlar if readily available to you.
