Bose amp location/replacement
Old May 21, 2017 | 08:19 PM
turboslut's Avatar
turboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant future
Hi guys...sound in wife's Cayenne (2011 CS) is all gone with the exception of the subwoofer. I checked continuity on each fuse in the panels on both sides of the dashboard and they were fine.
Does the Bose amp have a separate fuse onboard?
Anyone know where this amp is located? Anyone experienced this?
Old May 23, 2017 | 12:27 PM
turboslut's Avatar
anyone? not even the location?
Old May 24, 2017 | 11:00 AM
function12's Avatar
function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !
I believe it is in the rear cargo area. You might search dension and cayenne install and see what comes up. I believe they were make the most loop connections back at the amp.
Old May 24, 2017 | 11:07 AM
function12's Avatar
