cayenne 958 water into engine oil and "check coolant level" and water drain
Old Jan 26, 2018 | 08:30 AM
slc.zak3's Avatar
slc.zak3 is infamous around these parts
Hi everyone,
My cayenne S 2011 is loosing water ... that's is not the issue ...
I drive it from highway for about 3 KM after temperature raising from 90 to highest level in less then 3 seconds... I keep engine on for less than 35 seconds.
Small quantity of water mixed with engine oil (I guess less then 250 ML of water) and that's is the main issue
Is changing of engine oil and filter enough or Do I need to open the engine and make a turning for cylinders head at lathe shop ?
Is anyone had this experience, I need your help please.
best regards
Old Jan 26, 2018 | 04:45 PM
slc.zak3's Avatar
Originally Posted by slc.zak3
Hi everyone,
best regards
I want to clarify that I had add a water coolant a couple of times and warning gone and come back again after water drain ... drain problem solved ... I'm just afraid about engine
Old Jan 29, 2018 | 06:13 AM
Lapdancer996's Avatar
5 Year Member
Lapdancer996 is infamous around these parts
Well the longer you run that motor with mixture will make you have to rebuild it as that mixture is damaging the main bearings fast. I would look at the oil cooler as the issue.
Old May 27, 2022 | 04:35 PM
stv951's Avatar
stv951 is a jewel in the roughstv951 is a jewel in the roughstv951 is a jewel in the rough
Any updates on this issue ?
Because_R4CEC4R
Apr 10, 2018 07:49 AM
Yazz911TT
Feb 12, 2012 08:36 AM
Baps
Dec 16, 2003 10:21 AM
