Webasto fitted, but no aux. heat button on the buttonspanel
So i just bought a 2011 cayenne diesel, and to my surprise it was fitted with a webasto and the dealer wasnt aware of this.
I've tested it and it works, but im missing the button on the panel
have a look here, its the top right button with the flames on the lower buttons panel
https://images.finncdn.no/dynamic/96...1980194371.jpg
So is it just for me to buy this buttonspanel and the button will work?
I've got a piwis so some programming should be easily sorted if needed.
Also how about fitting a remote reciever, whats needed or is it even possible?
Doesn't Webasto offer a remote control for the heater? I seem to recall it being mentioned in other threads on the subject - so you can fire it off before you go out in the cold Norwegian winter to drive away..
So question is, is it only for me to buy a remote, pair it in some way and then im good to go? or do i need a reciever module or any thing else?
would be nice to sit in the sofa and fire up the webasto and go out to a warm car when its 0degrees fahrenheit out..
I'd lean more toward finding how to get a remote to work. But it'd be handy to have the console button, if just to be able to turn it off once you're on the road.
The panels are unique to the options installed in the vehicle. The whole button assembly gets replaced, not just a button. Does yours have a free location? If so then a panel with all your current options, plus the heater, should be something that could be ordered.
And i do agree the remote is most desirable, but beeing able to just open the door and press the button to get the webasto started would be nice to.
Right now i have to turn on the ignintion and browse my way through the menus.
If you're already seeing it in the PCM menus that might bode well for the correct button panel recognizing it.
I'm guessing you're going to have to contact Porsche directly to find out the correct part# for that panel.
mandown01
Aug 14, 2014 10:59 AM
vreynaud
Cayenne 955/957
Feb 23, 2009 09:40 AM
