Cayenne Turbo All Cayenne Turbo model topics
cooling problems or fans problems dont know
Old Jul 14, 2016 | 12:13 PM
Brady Miklos's Avatar
Brady Miklos is infamous around these parts
Angry cooling problems or fans problems dont know
Hi guys new on forum also new with cayene 955 turbo 06
i have cooling issues car runs good no misfires to get 180 cold start around 15 to 20 min,i dont feel high speed fan when start working i feel the air but i think need more speed dont know...
i dont know if normal when going up of 180 to 185 more or less turn on the fans ?
yesterday turn light coolant check,i check this morning i refill of coolant and close n tight the cap....later around 25 min with engine on i hear boiling in the expansion tank and fans turn on around 3 mins later turn off again boling start fans 3 to 5 min later turn off the fans and the temp around 185 and expansion tank pull out coolant.
what´s the first steps to check fans?termostat?cooling pipes?coolant pump?
sorry very sorry if have bad english just trying to figure out what kind problem have my car.
thanks aprecciate.
Old Jul 15, 2016 | 08:00 AM
bump help me
Old Jul 15, 2016 | 08:19 AM
porschecayenne92's Avatar
porschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant future
Hello , I have same problem with my panamera . You should have a leak or bad thermostat . Go check it at the dealer and keep us posted
Old Jul 19, 2016 | 11:51 AM
dan87951's Avatar
dan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to all
First, do you notice any coolant leaking? The coolant T's are made of plastic and are known to fail and leak coolant. Another known coolant problem is the plastic reservoir tank is known to fail around the seam.
As for the temperature if your car is sitting at 180-185 that is completely normal is not considered over heating. When you kick on the AC do the cooling fans kick on too?
flewis763
Jun 25, 2016 05:54 AM
turboslut
Mar 23, 2016 07:44 PM
MWILENS
Jul 24, 2003 09:23 AM
jgraham
Jul 13, 2003 11:07 AM
