Burning coolant
Old Jan 8, 2014 | 11:23 AM
kdog126's Avatar
kdog126 is infamous around these parts
Burning coolant
Posters...my 04 Porshe Cayenne S (65K miles) is burning anti-freeze and the repair thinks that head-gaskets is blown. What does that repair costs? Should I get it fixed or cut my loses?
Please advise.
Old Jan 8, 2014 | 01:56 PM
Renaissance.Man's Avatar
Moderator
Renaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond repute
Did you drain the oil? Unless I am mistaken, it you have a blown headgasket it will leak coolant into the combustion chamber where it will mix with the oil. Since the oil is water-based, it will be obvious if the oil is contaminated.
You should also do a compression test and cylinder leak down test to confirm before seriously considering a repair. Have these been done either?
Old Jan 8, 2014 | 01:59 PM
kdog126's Avatar
Not sure...I can call the shop and ask. Worth a shot I guess, I thinking it's going to cost a fortune. He did say that he found a leak from one of the hoses and he replaced it, but he still thinks the gasket is blown.
Glasgo
Nov 30, 2015 02:37 PM
COBB Tuning
Nov 3, 2015 08:39 AM
Jd1368
Oct 16, 2015 09:48 AM
freddiemac
Oct 7, 2015 11:05 AM
flewis763
Oct 4, 2015 04:14 PM
