CTT Secondary cooler install
This post should look very familiar as it was inspired by forum moderator Renaissance.Man which I'm proud to call a good friend. His research and attention to detail is top notch.
Imitation is not just the sincerest form of flattery-it's the sincerest form of learning and along the way I've learned a lot from Mr. Kent so I just wanted to say thanks for all the awesome posts that we always refer back to.
Off comes the Magnum bumper
Old return line cut. Less than one quart was dispensed.
On goes the industrial fittings.
NPT fittings sealed with LOCTITE 567 THREAD
Lines attached to cooler
Good time to clean the Evoms diverter valves
Back to the cooler upgrade
Techart bumper installed after painting everything black.
Finished just need a good detail now!
Let me be the first to say, Wow! Great job! Thanks for the kind words. This will make our transmission just that much more reliable. Not to mention the bragging rights you earned
Now lets get some Durametric ATF temp logs!
Jul 29, 2019 11:13 AM
ECS Tuning - VW
Aug 19, 2015 08:58 AM
