TPMS Fault
Old Feb 27, 2014 | 05:19 PM
JP911C4S's Avatar
JP911C4S is infamous around these parts
TPMS Fault
Below please see the TPMS fault screen shot. Just got a tire repair. Not sure if they did something with a sensor or I need to RESET somehow?
Every time I start my car I get this fault.
I appreciate your comments.
Thanks!
Old Feb 27, 2014 | 05:44 PM
RAKLAW's Avatar
RAKLAW has a spectacular aura aboutRAKLAW has a spectacular aura about
I'm familiar with system and resets but your picture isn't clear.
Can't read the script message
Old Feb 27, 2014 | 06:28 PM
JP911C4S's Avatar
TPMS Fault
Raklaw,
Oops. Sorry, the fault states " all-wheel drive system fault".
Tire pressure main Manu
Fill info - all four tires < +/- 3 psi (from 34 F/ 39 R setting)
Tire info- part load
Charge - all wheel, 18"
Old Feb 28, 2014 | 06:19 AM
RAKLAW's Avatar
Ok.
That error message does not usually relate to a tire issue. Admittedly it is no coincidence that it popped up after a tire repair but a TPMS sensor defect normally would not trigger that. Perhaps you tire guys messed up something during the repair. I suggest it be brought to an authorized P dealer who will plug in and see the error code its throwing
Old Feb 28, 2014 | 05:18 PM
MikeL's Avatar
MikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of light
I would take it to dealer and not say anything about getting the tire fixed or someone else touched the car. not that removing a wheel would trigger that, but would just stay quiet so they cant bs you about something. as far as you know, an error light came on while driving saying you awd system is faulty. they have to fix whatever is wrong under warranty.
Old Mar 1, 2014 | 12:51 PM
JP911C4S's Avatar
TPMS Fault -NOT!
Yup. Did the scan at a dealership today; It's the transfer case servo motor defect - ordered parts. It will be repaired next week under warranty - thank god!
need4speedmotors
996 Turbo Vendor Classifieds
Jan 12, 2016 05:41 PM
airbusdrvr
Dec 27, 2015 07:43 PM
C5tt
Oct 24, 2015 07:35 PM
freddiemac
Oct 7, 2015 11:05 AM
miken168
Oct 6, 2015 09:21 AM
