20" ruger-split sticking out...help!
Old Jan 25, 2015 | 01:47 AM
sasuav's Avatar
sasuav is infamous around these parts
I need some feedback. I just bought 20x10 ruger-split avant garde with 275/40/20 hankook ST on my 2009 Cayenne because I really like the concave look. ended up too wide and sticks out...Not happy at all Should I go 20x8.5 all around or 21x9 all around or staggered 20x10 in the back and 20x8.5 in the front? I'm so frustrated... any comments are highly appreciated.
Thank you!
ID:	412763   Click image for larger version
Old Jan 25, 2015 | 04:57 AM
Bader996's Avatar
Bader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud of
It looks good honestly
Old Jan 25, 2015 | 05:00 AM
loxxrider's Avatar
loxxrider is infamous around these parts
That all depends on if there are alternative offsets available. You may be able to get the same wheels in the same widths, which don't stick out as much.
Old Jan 25, 2015 | 09:04 AM
BG305's Avatar
BG305 is infamous around these parts
Front seems to be out more than the back in the second pic. Try lowering her to see if it changes the look for you. Also a 30 or 35 series tire might help.
Old Jan 25, 2015 | 09:18 AM
sasuav's Avatar
Thank you guys for your comments! BG305 yes, I'm going to put springs to lower her. I think so far H&R can go lower than eibach.
Old Jan 25, 2015 | 09:42 AM
Fuzzo's Avatar
Fuzzo is infamous around these parts
Is there any rubbing in the frint wheels
Guess the only thing you can do is to add spacers to the rear to even it out
Or bug a new set for just the front with a lesser offset
Old Jan 25, 2015 | 09:50 AM
BG305's Avatar
If you have a durametric cable you can check out RM's thread on lowering your cayenne with it.
Old Jan 25, 2015 | 10:21 AM
sasuav's Avatar
wow! I didn't even know what a durametric cable is... lol !
fuzzo, No they are not rubbing cause still too high... the weird thing is that these wheels are supposed to fit perfectly...ruger split are specially designed to fit porsche... I guess the offset is wrong. based on what the guys where I bought them from they say there is only one offset size... I think 40 0r 45...
Old Jan 25, 2015 | 11:58 AM
BG305's Avatar
This is the thread. It's pretty str8 forward and easy to do.
https://www.6speedonline.com/forums/...etric-diy.html
Old Jan 25, 2015 | 12:41 PM
sasuav's Avatar
Thank you so much for your time BG305. Excuse my ignorance but I think my cayenne doesn't come with air suspension my cayenne is base...am I right?? greatly appreciate it!
Old Jan 25, 2015 | 12:45 PM
HOiYA's Avatar
HOiYA is infamous around these parts
The base only comes with steelies, unless you ordered them. If you had air suspension, you would be able to adjust the height from the center console.
Old Jan 25, 2015 | 12:50 PM
sasuav's Avatar
Thanks HOiYA, that's what I thought...
Old Jan 25, 2015 | 12:54 PM
HOiYA's Avatar
Other option might be getting fender flares? Probably cheaper than new wheels and add to the aggressive look.
Old Jan 25, 2015 | 01:00 PM
BG305's Avatar
Correct only if if came as an extra.
Old Jan 25, 2015 | 01:03 PM
HOiYA's Avatar
Check out these at suncoast. The should also have ones that are primed for painting so they match your car exterior color.
http://www.suncoastparts.com/product...e=958V6MERbody
