2006 Cayenne Turbo S codes - p2401 & p0448
Old Mar 22, 2017 | 09:17 PM
06TTS's Avatar
06TTS is infamous around these parts
Hello everyone,
This is my first post but I have done tons of forum searching and found similar posts but nothing with my same codes. I have noticed a rough idle but once I drive the car drives great and boosts great. Along with the 2 EVAP codes I have P0300, P0301, P0304 and P0308. I have changed the spark plugs and I did a full inspection of the coil packs. The coil packs looked perfect, no cracks or damage and it needed new plugs so I did Beru plugs. In that process I changed the torque arm also because the rubber was shot. That didn't solve the misfire and I didnt notice any wiring issues or connector issues.
Onto the EVAP stuff. I have the two codes P2401 & P0448. Just put a new gas cap on and cleared the codes, they come right back. I also checked the oil fill cap and its seal looks great (no cracks in the oring).
Does anyone have any idea or run into these same symptoms? I have an appointment at my local Indy shop in a few days but would like to go in prepared. They're going to start with a smoke test looking for a vacuum leak.
Thanks in advance,
Evan
Old Mar 31, 2017 | 11:17 PM
DLF's Avatar
DLF
DLF is infamous around these parts
So you have a random misfire, and a few specific misfire codes, and also Evap leak and evap vent codes. In my opinion, all point to a vacuum leak somewhere.
So vacuum test is the right way to go. May also be a leak on the air oil separator.
