Cayenne Turbo Vibration when Stopping!!! Help
Old Dec 13, 2018 | 10:16 AM
Coppertop44's Avatar
Coppertop44 is infamous around these parts
Exclamation Cayenne Turbo Vibration when Stopping!!! Help
Hello all
I'm reaching our for solutions
I have a 2004 Porsche Cayenne Turbo and my issue is, when coming to a stop of any kind the car vibrates and idle dips ever so slightly. I have changed out the spark plugs and coils, Drive Belt, and the Secondary air injection system P0491 code threw at me just recently. I'm at a loss at this point...
When coming to a stop if I put it into neutral it doesn't vibrate. When it's cold it's worse.
Thoughts???
Old Dec 14, 2018 | 10:02 PM
Zuffenhausen955's Avatar
Zuffenhausen955 is infamous around these partsZuffenhausen955 is infamous around these parts
Replace your torque strut....
Old Apr 15, 2019 | 12:45 PM
sswong98's Avatar
sswong98 is infamous around these parts
I have the same issue. When my 2006 Cayenne S about to come to a stop, I feel a little vibration. I don't feel it when I put the car into neutral. The front brakes (pads and rotors), torque strut and lower control arms have been changed out. I am wondering if the issue is motor or trans mount? I haven't noticed a drop in idle and I have no codes.
Old Apr 28, 2019 | 12:05 AM
racer_65's Avatar
racer_65 is infamous around these parts
Same issue with my 2006 Cayenne S. I guess "they all do that". I've searched various forums over the years. No definitive solution has ever been posted. The most common hypothesis are:
1) Cracked coils, even those that don't throw a code.
2) Vacuum leak in air-oil separator cap. Replaced mine, and it did not solve my problem.
3) Leaking motor mount. Not easy to replace.
Old Sep 24, 2019 | 09:11 PM
Vicente's Avatar
Vicente is infamous around these parts
Hello,
I have a 2004 Porsche Cayenne Turbo and while driving the car seems to shift into neutral on its own.The brakes all of a sudden do not work and when I press on the accelerator it just revs but does not go anywhere. I have searched everywhere and cannot find anything similar in these forums.
The thing is it happens maybe 1 once a month so very hard to reproduce. Seems to happen mostly at very low speeds under 20 mph or when at a complete stop idling with my foot on the break.
I have to turn the engine off and try to restart the car. Usually I only need to try and restart once and the car is back to normal.
The last couple of times it did happen it was around 90 degrees outside. Kind of lost on this one.
Old Sep 24, 2019 | 11:26 PM
There has been a worldwide recall, on the shift bushings. Get the dealer to install and look into the ghost shifts too.
Old Aug 19, 2020 | 09:57 PM
Tecchie's Avatar
Tecchie is infamous around these parts
Research I've done points to the AISIN transmission in our vehicles. Specifically Valve Body issues. I have the same issue when coming to a stop. All mounts are good and solid. I had my mechanic check. Some of the symptoms I have in addition to that are the hard 5-4 downshift when under heavy acceleration, and an occasion of a 4-5 shift flare under full throttle... Other than that, it works totally fine. But for some reason, these AISIN transmissions use aluminum in certain areas of the valve bodies that wear out and cause issues over time. I have similar issues on my VW Jetta that uses the same series but front wheel layout. and obviously built for far less power. But they used the ****ty parts on all these transmissions, which is probably why Porsche switched to the PDK (which is ****ty for off-roading really, cause akin to the DSG found in VW/Audi vehicles..
I thought about tackling the valve body swap myself, but seeing as this is my current DD, I can't afford the downtime if I **** something up... The valve body is far cheaper than replacing the whole unit, but I'm not against looking into the cost of a rebuilt unit that has all the updated parts in it.. I just can't afford the probable $5k+ it may cost to replace it as I only paid $9,200 out the door for my 2005 Turbo. I do plan on keeping it for the long haul even if repair costs exceed its value. But that's me.
Yotam Refael
Jul 27, 2015 01:38 PM
SFdreamer
Feb 23, 2015 08:36 AM
Jan 8, 2015 09:01 PM
C4SxM5
Mar 7, 2014 11:12 AM
911-AL
Jul 24, 2012 04:22 PM
