4.5 misfiring
Old Jan 16, 2021 | 04:12 PM
Legobrick's Avatar
Legobrick is infamous around these parts
4.5 misfiring
So my cayenne has started to develop a very annoying problem recently. Its starts to misfire/ bog down between 2-4k rpm under heavy throttle. Drive it gently and its smooth, wait until it's up over 4k and no issues at all under light of full throttle.
No eml light but when scanned the only code that came up is p0344 cam sensor intermittent bank 1. Both sensors have been replaced, as well as coil packs, plugs , battery and oil( needed a service). The wiring appeared to be fine and tested ok for continuity.
Has anyone had a similar issues before as its driving me mad now. Could it possibly be a bad actuator causing the the timing issues but not creating a code?
Old Feb 10, 2021 | 11:00 PM
gibbsy's Avatar
gibbsy is infamous around these parts
4.5 misfire hesitation.
Had a similar issue on mt ctt. Solved by cleaing intake and intercooler of fugitive oil and the replacing air oil separator. Now no issue
Old Feb 10, 2021 | 11:34 PM
Legobrick's Avatar
if only it was that easy, turned out that the intake cam on bank 1 was out of position. Reset the static timing and all fixed now.
DaveSen
Cayenne 955/957
Jan 7, 2019 07:48 AM
nbbturbo
Feb 10, 2017 09:29 AM
jaennette93
Cayenne Turbo
Feb 8, 2016 07:06 PM
knicks
Cayenne 955/957
Jun 27, 2012 09:06 PM
