2014 Cayenne GTS - success w/coolant leak fix kit?
Old Jun 10, 2024 | 08:25 PM
2014CayenneGTS's Avatar
2014CayenneGTS
My 2014 Cayenne GTS has a tiny leak that looks to be coming from one or both pipes underneath the engine (apparently there are some rubber or plastic parts which may have deteriorated. I was made aware of the leak when the sensor came on, but when I checked the coolant level there appeared to be plenty of coolant. There was no visible coolant leaking beneath the vehicle(, which I checked for each time the message came on.
Has anyone successfully used a coolant fix kit without otherwise causing damage to their Cayenne? I normally wouldn't consider doing this but it was suggested to me by someone and I wanted to get verification from anyone else who has tried doing this. If so, which coolant fix kit is the best option for my vehicle? is there an OEM kit? I haven't been able to find one but figured it wouldn't hurt to ask. An estimate to access and replace both pipes is approximately $2,000.
Thanks for any helpful feedback.
Check Coolant Level message
Photo of the suspected leak area
Diagram of potential pipe(s) that are leaking.
douglas61
Cayenne 955/957
Feb 6, 2023 08:58 PM
kdog126
Cayenne 955/957
Jan 13, 2014 07:23 AM
EuroTechMS
Cayenne 955/957
Jun 25, 2012 06:26 AM
florez773
Cayenne 955/957
10
Jun 20, 2011 07:57 PM
motoadve
Cayenne 955/957
Aug 24, 2009 08:54 AM
