how do i get this dirt off my wheels?
Old Mar 22, 2008 | 11:27 PM
momoney's Avatar
momoney is infamous around these parts
i have tried meguiars wheel cleaner and that has not removed the grime off the wheels what should i use. here are the pictures of my wheels:
Old Mar 22, 2008 | 11:30 PM
Zach's Avatar
Zach is infamous around these parts
My wheels get really dirty....this stuff helps tons:
http://www.google.com/search?source=...=Google+Search
Old Mar 23, 2008 | 09:13 AM
MoeMistry's Avatar
Premium Sponsor
Very simple. What you have there is embedded brake dust as a result of not washing the wheels often enough or with a good wheel cleaner. The remedy is simple; clay the wheels. After you clayed them, apply a protectant like RejEx and make sure you wash your wheels as often as you drive. Daily drivers should be washed weekly and cars that go out on the weekend, can go every two weeks. Use a mild, pH balanced wheel cleaner like zymol Wheel Cleaner.
Old Mar 23, 2008 | 08:48 PM
momoney's Avatar
I tried the clay bay and it did not work, i still have those embedded brake dust spots. Is there anything stronger that wil remove the embedded brake dust?
Old Mar 23, 2008 | 09:03 PM
JoshVette's Avatar
JoshVette is infamous around these parts
They look like painted rims correct?
Wow, that's a toughy, if the clay won't get it out, it must be really burnt in to the paint, try some 3M adhesive remover. If that doesn't work, the only other thing that really comes to mind is a mother's power ball and chemical paint cleaner or possibly even an abrasive polish....
I agree with Moe, once you get it thoroughly cleaned, apply some protection like rejex or a good AIO like Zaino or Klasse AIO.
Regular maintaince and waxing them will help you avoid this in the future.
Josh
Old Mar 23, 2008 | 10:13 PM
vick57's Avatar
vick57 is infamous around these parts
i have tried meguiars wheel cleaner and that has not removed the grime off the wheels what should i use. .....
have you tried PS21 finish restorer? i switched to it from mothers wheel polish.
Old Mar 23, 2008 | 11:09 PM
MoeMistry's Avatar
Premium Sponsor
What clay did you use? I usually clay using zymol lehm klay and then whatever I cannot get off, Menzerna SIP does it for me. Hope this helps.
Old Mar 23, 2008 | 11:46 PM
JoshVette's Avatar
Moe, have you used SIP on rims for burnt in brake dust?
Just curious...
Old Mar 24, 2008 | 06:34 AM
MoeMistry's Avatar
Premium Sponsor
Just curious...
On wheels that are clear coated, you can use a polish like SIP to get the last bit of brake dust that claying won't remove. Works like a charm for me since I don't use harsh chemicals or wheels acids.
Old Mar 24, 2008 | 12:15 PM
JoshVette's Avatar
I don't use them either, but for this situation I would give some 3M Adhesive Remover a shot, it's clear coat safe.
Thanks for the referal btw Moe.
Josh
Old Mar 24, 2008 | 02:27 PM
Stealth 993's Avatar
Stealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond repute
Clay should totally remove it.
If not, try & get a harder clay, or as Moe said, polish it, but it's going to be by hand, & take some time.
I would be very careful if you go the harsh acid, cleaner route.
Old Mar 24, 2008 | 11:04 PM
momoney's Avatar
where can i get the SIP polish with a reasonable price?
Old Mar 24, 2008 | 11:51 PM
MoeMistry's Avatar
Premium Sponsor
Please PM me your info and I'll ship it out to you.
Old Mar 24, 2008 | 11:52 PM
MoeMistry's Avatar
Premium Sponsor
Josh
You're welcome Josh. Take good care of the car and the client
Old Mar 25, 2008 | 08:22 AM
JoshVette's Avatar
Always...
