Advice needed
Old May 22, 2008 | 06:05 PM
Zaks's Avatar
Zaks is infamous around these partsZaks is infamous around these parts
Originally Posted by mathism
Ivan - I really appreciate your offer. I've already hit it with a clay bar, wax cleaner and polish to no effect. I don't think I want to do a wet sand. The more I look at the rest of the hood, the more I lean toward having it painted. It would be nice if these stains went away and I could wait another few months (damn property tax bill due in a few wks). Once it is painted, I need to have the whole car professionally detailed.
I'm headed to Lake Geneva for the wk end. If you buzz by a black 335 coupe or 911 with a foggy "50" on the hood, thow me a sign!
Gotcha. Well get in touch for a detail once you're ready if you don't already have your own detailer. Best of luck with the hood. I know a great guy who does painting but he's in Palatine, so if you don't know anyone closer, PM me and I'll give you his info. Only painter I can say that I actually trust as a detailer haha
Oh and I'll be on my black '07 zzr600.. I'm leaving pretty early though as I want to do tons of riding before the rest of the people, who are driving, catch up.
Old May 23, 2008 | 07:26 AM
MasterDetailing's Avatar
MasterDetailing is infamous around these parts
I would also try a damp rag with rubbing alcohol on it right after you put heat on it. Apply heat then apply the damp rag. Try that first, if no luck I'd go the wet sanding route. Then of course if nothing works then a repaint.
Old May 23, 2008 | 07:30 AM
MoeMistry's Avatar
Premium Sponsor
It usually takes a few weeks in the sun to get the moister out of the paint. But if the actual basecoat is damaged, which in this case it looks to be through the clear and maybe the base, wet sanding isn't going to do anything. I'd say give it a good week or two in the sun, then if all else fails, repaint. If you do repaint, wait a month or so and then put a clear film on the front to avoid this.
Old May 23, 2008 | 11:20 AM
mathism's Avatar
mathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond repute
A few weeks in the sun?? Hurts me to think of leaving her out in the mean sun that long....
Old May 23, 2008 | 11:26 AM
MoeMistry's Avatar
Premium Sponsor
I know...but it needs the heat, and UV, from the sun to clear things up. Would you rather have a repaint or original paint? It's worth a try. If it works, saves you thousands $$$, if not, repaint was in order anyway.
Old May 23, 2008 | 12:16 PM
Its hard to explain my technique but back when I was doing dealer work I would use a spray bottle with a 50/50 or 70/30 mixture of water and rubbing alcohol and a heat gun. I would heat the panel in circular motions then mist the panel with the mixture then wipe. Repeat as much as it took and followed with my normal paint correction procedure. I must warn you heating a panel with high heat from a heat gun is dangerous. Start with a low setting then up the heat as needed. Of course this is just away to expedite the correction. ( if it is moisture migration )
Old May 23, 2008 | 07:15 PM
jjc4scab's Avatar
jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !
Try finding a detail shop to do it if not your self. I just sold my 993 to a dealer and he went over every curve and flat panel with a paint depth gauge. He told me if the paint was thicker then factory depth he didn't want the car. He said as soon as a person sees paint work (not brush touch) they think the car has been smacked.
Old May 24, 2008 | 09:03 AM
mathism's Avatar
The rubbing alcohol left the surface blurry. Is that the wax or polish it is removing? I tried to wipe it down with a detail spray and MF towel, then even a clay bar and it is still blurred. Too strong of alcohol?
.... quickly moving toward a respray.
Old May 24, 2008 | 02:58 PM
The alcohol removes both wax and polish. The alcohol is used to help dry out the moisture. The blurring can be corrected with polish by hand or machine.
Old May 25, 2008 | 12:42 PM
mathism's Avatar
Well, it looks like good news. After the alcohol bath, the water spots were gone. I was left with the smears. I used a clay bar, then paint polish and it is all cleared up! Thank you all for the expert advice. Now, I'm back to just paint chips and swirls to work through. Thanks again. This thread is a great resource for us amateurs...
Old May 25, 2008 | 02:26 PM
Im glad it all worked out for you Sorry for the scare with the blurring, it does'nt always have that reaction. At any rate you back in order, well as good as it was b4
Old May 25, 2008 | 07:03 PM
MoeMistry's Avatar
Premium Sponsor
AWSOME Glad to hear it worked out. I've seen this many times and usually I tell clients to wait as I did to you. But I think the alcohol trick worked well and sped things up.
Old May 25, 2008 | 07:13 PM
J_Edwards's Avatar
J_Edwards is infamous around these partsJ_Edwards is infamous around these parts
Really glad to hear that worked out, and I am excited to hear that trick, that was something that I hadn't heard before.
Old Jun 1, 2008 | 07:24 PM
Thats an old trick I used to use about 10yrs ago on Audi's when they would come in off transport, moisture would get traped between the plastic and the paint and once it heated up from the sun the moisture choose the easiest path to go.
VGLNTE1
Aug 24, 2015 12:23 PM
00aston
Aug 24, 2015 09:29 AM
Fadi
Aug 21, 2015 03:43 AM
Rumrunner
Charity Notices/Events
Aug 20, 2015 11:07 AM
