Smoke Detailed :: 25hr Correction:Carbon Black M5:Signature Gloss
Old Jul 19, 2008 | 12:39 PM
Smoke7's Avatar
Smoke7 is infamous around these partsSmoke7 is infamous around these parts
Originally Posted by JoshVette
Nice job on the M5, but I'm really surprised that it took you so long on such soft paint??
I did an identical M5, carbon black, a couple years newer though and the swirls were just as bad, maybe yours were deeper though?? and I cut them with M105 on a white LC pad with a rotary and achieved near perfect results with minimal efforts. There was a very slight haze left over which was easily corrected with the PC and some ZPC and the paint was show ready.
After reading your write up, it seems like maybe you were trying to get full correction with no holograms all in one shot, but that's not possible for most cases, typically you'll have to do the heavy cutting to remove defects which will leave holograms but fully polish out swirls, then go back and refine the finish 1-2 more times each time polishing out the holograms till it's perfect.
On super soft paints you just can't finish down with a rotary or flex, you have to use the PC with gentle pad/polish combos.
Josh
I always do a 2 step (or sometimes 3 step) process. First is correction than finishing, if you get holograms after correction than I just finish it off with a lighter polish and work it slowly. Some cars require a 3 step where 2 steps of correction are needed. This car, having super soft paint was very difficult to work with because of the level of correction required and the pictures dont show the real amount of swirls and RIDS, i wish I had pictures of the trunk on a wide scale in the sun and you would see what im talking about.
I would have liked to use a minimally agressive polish and go over the car twice to remove the defect and then follow up with a finisher but it wouldnt have been enough to remove the deeper RIDS and the owner wanted a full correction. I knew no matter what I did for correction I would get severe holograms so I went with a least agressive methods I could to achieve heavy correction by working in descending order of agressiveness in both pad choice and polish choice.
So I worked SIP on both machines at very slow speeds, this is one reason why the polishing process took so long. Getting SIP to breakdown fully at well under 1500rpm is a real pain. And using 3M ultrafina like I did it took even longer, that is a polish I normally work at 1800rpm! It was after every step I had to jewel the finish slower and slower using almost no pressure to ensure no holograms were left. And every single panel got a full correction job including the roof. So yes it took a very long time but to get perfection and finish with no holograms thats how long I needed.
Old Jul 20, 2008 | 07:09 PM
93VIPERBOY's Avatar
93VIPERBOY is infamous around these parts
Great job
Old Jul 20, 2008 | 09:19 PM
damon@tirerack's Avatar
Moderator
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Old Jul 22, 2008 | 03:47 PM
Smoke7's Avatar
Originally Posted by damon@tirerack
Thanks guys
Old Jul 22, 2008 | 04:29 PM
3.5g's Avatar
3.5g is infamous around these parts
Looks sick
Old Jul 24, 2008 | 04:56 AM
4tirefire's Avatar
4tirefire is infamous around these parts
Beautiful job, lots of blood and sweat.
Old Jul 25, 2008 | 01:47 PM
Smoke7's Avatar
Little bit of the first one, lots more of the latter
cnebrask
Oct 3, 2024 08:19 PM
albert@velosdesignwerks
Other British Cars
Aug 22, 2015 06:13 PM
