Removing Scratches From Plastic?
Old Aug 17, 2008 | 09:20 PM
Zookie's Avatar
i tired Meguiers PlasticX to remove swerls and scratches from my Head and Tail Lights, but it dint help at all... I applied it by an Orbital Machine w/Wax Applicator Pad...
What is the proper way to do it and what should i use?
Old Aug 17, 2008 | 09:42 PM
Smoke7's Avatar
Smoke7 is infamous around these partsSmoke7 is infamous around these parts
Can you feel the scratch with your fingernail? If so PlasticX wont cut it.
Old Aug 18, 2008 | 01:58 PM
95RogueM3's Avatar
95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of
You might also try Plexus. Its an aersol plastic polish that I LOVE.
Ive also used more abrasive car polishes and even Mother's Mag and Aluminum polish on some severely pitted headlights before with great results. Granted that was on my beater Ford for which I wasn't too worried about the outcome.
As was said above, if they are bad enough you can feel them with your fingernail, you are probably out of luck.
Old Aug 18, 2008 | 05:18 PM
detailjohn's Avatar
detailjohn is a splendid one to beholddetailjohn is a splendid one to beholddetailjohn is a splendid one to beholddetailjohn is a splendid one to beholddetailjohn is a splendid one to beholddetailjohn is a splendid one to beholddetailjohn is a splendid one to behold
I think the problem is that you were using a wax applicator pad. You need to polish it similarly to paint, start with a wool buffing pad, and work you way down to swirl mark remover, then ultrafina. If you don't have the chemicals yourself, just take it down to a local detail shop, and they should be able to take care of it for you.
John
Old Aug 18, 2008 | 08:37 PM
Zookie's Avatar
Originally Posted by detailjohn
I think the problem is that you were using a wax applicator pad. John
yea thats what i thought... just light swirls and nothing deep to be felt with finger nails... So i should use a Polishing Pad right?
Old Aug 18, 2008 | 08:47 PM
detailjohn's Avatar
yup. The wax applicator pad won't do much polishing. You could also have Venture Shield applied on the the lights, and it should cover most of the scratches.
John
Old Aug 18, 2008 | 10:05 PM
Zookie's Avatar
Whats that? Clear Bra?
Old Sep 11, 2008 | 07:36 AM
MoeMistry's Avatar
Premium Sponsor
You need to use a true polish like Menzerna SIP or 106ff with a more aggressive pad. Usually SIP, Orange pad, and a flex or pc will do the trick. You can then follow up with another polish/pad combo like 106/white pad and finish off the lights.
VentureShield is a clear film that will simply hide everything underneath. It's like a thick seran wrap that is applied to the paint and is durable and prevents rock chips and scratches. Hope this helps. Let me know if it's not making sense.
Old Sep 11, 2008 | 10:37 AM
Zookie's Avatar
thanks ill give that a try
DLF
Cayenne 955/957
10
Feb 28, 2022 11:49 PM
SM_ATL
Mar 26, 2016 03:02 PM
jaehoppa
Oct 22, 2015 09:17 PM
sleepy
Sep 4, 2015 11:59 AM
