Conours Finish Detailed: Black Mercedez SL600
Old Oct 15, 2008 | 06:20 AM
Concours Finish's Avatar
Concours Finish is infamous around these parts
Mercedez Benz SL600
Wheels, Wells & Tires
P21s Wheel Gel Cleaner
Meguiars APC +
Jet Seal 109 to seal wheels
Various Brushes and Foam Tip Swabs
Megs Hyperdressing Tire Shine
Exterior Wash
P21S Total Auto Wash Pre-soak
Chemical Guys Citrus Wash & Gloss
Clay
Chemical Guys Blue Clay
ONR used as Clay Lube
Paint Correction
LC Purple Foamed Wool with Menz SIP
LC Orange Pad with Menz SIP
LC White Pad with Menz PO106FF
Trim
Black Wow
303 Aerospace Protectant
Prima Clarity Glass Cleaner
Glass Polishing Cloth
Meguiars NXT All Metal Polish
Interior
Prima Nero
303 Fabric Guard
Prima Nourish Leather Conditioner
LSP
Chemical Guys Jet Seal 109
Chemical Guys 50/50
Equipment
5.5 Hp Rigid Shop Vac
Karcher Electric Pressure Washer
Cam Spray Foam Cannon
Makita 9227c
Porter Cable 7424
LC 6.5" pads & 4" pads
Thought I'd take a photo of most of the products used
Before Photos
Car looks good in the shade from afar......
But in the sun close up you get.....
Old Oct 15, 2008 | 06:21 AM
Foam Tipped Swabs from AutoGeek. Great for calipers, lug nuts, and other small hard to reach areas.
Can't forget behind the wheels...
Prepped for Trunk 50/50
Before
After
I always like taking the car outside under the sun to take 50/50s because the sun shows the defects best......
Up Close
Can you tell I like 50/50s ???
Closer
Fender 50/50
Old Oct 15, 2008 | 06:22 AM
Before
After
Before
After
50/50
Old Oct 15, 2008 | 06:23 AM
Afters
Old Oct 15, 2008 | 09:07 AM
Gloss-it's Avatar
Gloss-it is infamous around these parts
Very impressive! Great 50/50 shots
Old Oct 19, 2008 | 09:35 PM
Roman m's Avatar
Roman m is infamous around these parts
may I ask what product you used to remove the swirls?
I assume you used the product with a power buffer, then wiped it off with a towel, Right?
Old Oct 20, 2008 | 04:20 AM
Its all listed in the beginning of my post under paint correction:
Paint Correction
LC Purple Foamed Wool with Menzerna Super Intensive Polish
LC Orange Pad with Menz Super Intersive Polish
Old Oct 20, 2008 | 08:27 AM
auto concierge's Avatar
auto concierge is a splendid one to beholdauto concierge is a splendid one to beholdauto concierge is a splendid one to beholdauto concierge is a splendid one to beholdauto concierge is a splendid one to beholdauto concierge is a splendid one to beholdauto concierge is a splendid one to behold
Thumbs up Super Clean
I like to see all the right things done to effect a proper correction... proper tape masking, plate removal ect... . I have not been fond of the purple foamed wool pads as they can cause deep holograms,however maybe they work better with Menzerna compounds and polishes which I no longer use all the same this car looks great!!.
pshep138
Sep 1, 2015 09:45 AM
Wheel Experts
American Muscle
Aug 19, 2015 09:07 AM
Wheel Experts
Wheels/Tires
Aug 19, 2015 09:05 AM
