Full Wheel Cleaning
Old Mar 9, 2009 | 07:50 PM
omarresto's Avatar
omarresto is infamous around these parts
use plain soap and water or dish detergent there are many wheel cleaner out there make sure it is clearcoat safe.
Old Mar 9, 2009 | 09:49 PM
MoeMistry's Avatar
Premium Sponsor
Using plain water will not fully clean the wheels. You will also scratch the finish of the wheels since there's no lubricity between the brake dust and your brush or towel.
Using dish soap is like washing your car with dish soap. Dish soap has ingredients in it to break up grease or fatty acids and oils. Most of today's wheels are clear coated much like your paint. Using dish soap will remove the inherent oils in the finish of the wheels. This will dry out the finish of the wheels and over time will oxidize them.
Best thing is to use a safe, pH balanced wheel cleaner made specifically for wheels. There should not be any harmful petrochemicals or acids in the cleaner as it will hurt the wheel and the environment. P21S wheel cleaner, zymol wheel cleaner, and swissvax wheel cleaner are a few safe and effective options.
Old Mar 10, 2009 | 07:39 AM
JoshVette's Avatar
JoshVette is infamous around these parts
Originally Posted by tejoe
Last month a concours detailer (Tampa, florida) told me he used brake fluid rather than wax to help keep the brake dust off. Doesn't make great sense to me but he has a pretty good following. Anybody else do this?
Who is this detailer?? I know who it wasn't but instead of leaving everyone thinking it was one in particular why don't you clear up our curiousity.
To the OP, if the break dust build up has etched into the finish then it will not simply clean off no matter what you use. You will have to either refinish the surface or find a way to remove the damage by hand or possibly with the power ball or something.
Josh
Old Mar 10, 2009 | 07:44 AM
tejoe's Avatar
tejoe has much to be proud oftejoe has much to be proud oftejoe has much to be proud oftejoe has much to be proud oftejoe has much to be proud oftejoe has much to be proud oftejoe has much to be proud oftejoe has much to be proud of
detailer
Reasonable point; I got his card and will find and post.
Old Mar 12, 2009 | 12:54 PM
SoCal911's Avatar
SoCal911 is infamous around these parts
got to get those wheels clean !
Old Mar 12, 2009 | 01:56 PM
bsquared's Avatar
bsquared is infamous around these parts
P21S products are some of the best. Best to do one wheel at a time. If you don't want to buy a jack, use the one that came with the car. Definately use a jack stand while the wheel is off the car. Depending on the car you may want to use a flat top jack stand to keep from damaging the underneath of the car. I have a 911 and like the flat top jack stands from Northern Tool.
The_Ruski_Driver
Oct 25, 2015 08:40 PM
MurderedTurbo
Aug 28, 2015 09:06 AM
Aug 21, 2015 09:56 AM
roncooper
Aug 19, 2015 01:17 PM
