Zymol Glasur "Porsche Wax"
So whats the deal with Zymol's Glasur Porsche Wax. Is this wax for real or is it some sort of marketing tactic?
Whats different about this wax from say a Carbon or Creame Wax (or any other brand for that matter)?
Whats special about the Porsche finish that it needs a special wax?
Thanks You.
Thanks You.
It depends on how you want to look at it. Some see it as a marketing tactic, while others may not. There are some waxes on the market that are "formulated" for different finishes, since each manufacturer doesn't use the same paint or process.
I think Glasur is a great wax, especially on Black paint. I like it, and it's easy to use.
I never really understood a "marquee" brand of wax. Hence why I never sold them. You're better off getting a wax like Zymol Concours or Swissvax Concorso. They can be used on ALL paints...not that Glasur couldn't be used on ALL paints either. It's just good marketing to the Porsche, Ferrari, BMW, etc. crowd.
Matt
The aesthetics of a vehicles appearance is often based on an emotional reaction, which is very subjective to say the least
Live long and prosper my friend.
"Does this wax work with machine application Porter Cable 7424? Does mercedes Benz use Glasur paint also ?"
This question worries me a little bit. With all the great easy on, easy off options, why would you apply a wax with a PC? I have heard of some using a machine to buff off some really hard carnubas...but for application?
Maybe I am missing the boat somehow, but waxing is all about smearing some goop on the paint...no need for heavy pressure or 10 million cycles with a machine...you then remove all but a thin film of the goop...the thin layer of goop protects the paint. It has nothing to do with smoothing the surface or modifying the paint in any way.
A machine application enables a thin even layer of wax / sealant.
For the purist -
Spatial reflection – [: law of reflection says that for smooth surfaces, the angle at which light is incident on the surface equals the angle at which it is reflected.] the perfect, mirror-like reflection of light from a surface, in which light from a single incoming direction is reflected into a single outgoing direction. The best example of spatial reflection is seen when reflected from a flat level surface
For others –
A thin layer of wax / sealant is all that is required, with polymer; it cannot be emphasized enough ‘Apply products very sparingly’ Ease of product removal is inversely proportional (less product easier removal) to the amount used
For the purist -
For others –
As far as I know, Mercedes uses PPG and Standox as their paint; not glasurit.
I just bought the Glasur wax from www.MyAutoCarCare.com
I can't express how impressed I am with the wax. I have always used the Carbon wax and thought the Glasur was just a gimick. Definatly not. If you own a Porsche, you should defiantly spend a little more for this wax.
2lflat4
11-18-2019 05:05 PM
joseph_number1
07-19-2018 05:45 PM
AJUSA.com
997 Vendor Classifieds
10-08-2015 05:50 PM
08-20-2015 12:17 PM
