My Sister & Sister-in-Law Bought me a CR Spottless for my B-day!
Old Jan 31, 2010 | 11:03 AM
DrScoles's Avatar
DrScoles has a spectacular aura aboutDrScoles has a spectacular aura aboutDrScoles has a spectacular aura about
I'm in. How about a package with the foam gun too???
Old Jan 31, 2010 | 05:39 PM
MoeMistry's Avatar
Premium Sponsor
Sounds good to me....we just need more people so I can get better pricing. We'll need at least 5 people...hopefully 10. Keep in mind, we sponsor 4 forums...so that's 5-10 across all forums.
Old Feb 1, 2010 | 03:29 AM
sethm2's Avatar
sethm2 is infamous around these parts
moe,
sent u a pm
Old Feb 1, 2010 | 07:10 AM
MoeMistry's Avatar
Premium Sponsor
Originally Posted by sethm2
moe,
sent u a pm
got your pm...will respond shortly.
Old Feb 1, 2010 | 08:46 AM
g8rdmd's Avatar
g8rdmd is a splendid one to beholdg8rdmd is a splendid one to beholdg8rdmd is a splendid one to beholdg8rdmd is a splendid one to beholdg8rdmd is a splendid one to beholdg8rdmd is a splendid one to beholdg8rdmd is a splendid one to behold
Sweet, keep us informed I don't necessarily need the foam gun, I've got a pressure washer with a foam gun already, but I definitely do want the DIC-20 (that's the larger unit on the cart, right?).
Old Feb 1, 2010 | 09:20 AM
DrScoles's Avatar
I saw it for $449 on a detailer site, and $369 at costco. Moe, do you think you can beat costco's price?
Old Feb 5, 2010 | 03:08 AM
MoeMistry's Avatar
Premium Sponsor
Old Apr 30, 2010 | 03:06 PM
alevine's Avatar
alevine has a spectacular aura aboutalevine has a spectacular aura about
As a follow-up to my original post a few months ago I finally cracked open the box and washed my car with the CR Spotless for the first time last night. Wow, I am quite impressed! The thing actually works! After washing with my Karcher pressure washer I used a silicone squeegee and an electric leaf blower to remove 95% of the water but the car looks amazing! I am pumped!
BTW, when I went to install the 2 white PVC adapters that came with the CR Spotless into the side of the system one of the adapters broke. I took them to Home Depot and purchased both adapters in brass along with various quick connect valves, etc. and it works awesome. I would definitely recommend you spend the $20 for these little add-ons. BTW, if you plan to replace the plastic pvc adapters with brass ones the part you need is a hose connection on one end and a pipe (plumbing) connection on the other. I found them in the plumbing section.
Adam
Old Apr 30, 2010 | 11:52 PM
Greg Nichols's Avatar
Greg Nichols is infamous around these parts
Adam
Good for you Adam!
You can just leave the DI water on the car, no need to use the squeegee, you will lessen the possible marring.
Here is something to remember. DI water is going to oxidate any brass, hence the reason thoes pieces are plastic. Same thing with your pressure washer, ALWAYS run non di water through it afterwards to conserve the internal metal pieces. I know from experience what it will do to metal if left in LONG term contact.
Cheers,
GREG
Old May 1, 2010 | 07:54 AM
MoeMistry's Avatar
Premium Sponsor
Adam
Glad you love the system Adam....thanks for your business.
As Greg mentioned, you may notice the brass corroding due to coming in contact with di water...I noticed some new aluminum fittings from gilmore that might be better. They look like brass but weigh about a 10th...I'll find out from CR if those will work better.
Old May 1, 2010 | 05:56 PM
alevine's Avatar
Hmm, good to know. I had no idea that DI water will oxidize the brass. All of my quick disconnects, etc are brass. Just out out curiosity, will the oxidation ruin anything or is it simply aesthetic?
Adam
Old May 1, 2010 | 07:32 PM
bonehead's Avatar
bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !
Originally Posted by Greg Nichols
Good for you Adam!
Cheers,
GREG
Yikes. Great tip. Didn't know that. I use the PVC fittings, but I don't know what kind of damage it's doing to my pressure washer internals. Guess I'll run the tap water thru before I store it from now on.
Old May 2, 2010 | 08:30 PM
I have a foam cannon, the internals are brass, the finer sized pieces got a bit oxidized and effected the spray pattern. I cleaned the parts works fine now, but I always run tap water afterwards (cleaning up washing area).
Cheers,
GREG
Old May 4, 2010 | 02:45 PM
alevine's Avatar
BTW, I think I discovered one other benefit to the CR Spotless. My car is a darker shade of blue and normally attracts dust pretty quickly. In fact, I usually use my California duster 3 times per week or so between washes. What I have found is that I have not needed to use the duster on my car since I washed it 5 days ago! It still looks amazing!
Can that be from the de-ionized water? Maybe the microfiber towels create static electricity that attracts dust??? Any ideas? Great side benefit though!
Adam
Just Cruise
Canada
11
Jan 8, 2017 08:04 PM
Most-Wanted
Merchandise For Sale / Wanted
Dec 8, 2015 08:58 PM
drug delivery
Oct 24, 2015 11:04 PM
Just Cruise
Sep 19, 2015 01:28 PM
fjwheeler
Sep 19, 2015 10:56 AM
