Quick & Easy Bug Removal w/Diamondite Bug Eraser
Old Apr 29, 2011 | 09:21 AM
Nick@Autogeek's Avatar
Nick@Autogeek is infamous around these parts
Love bug season is here already in Florida and if you guys are as particular about keeping your car clean as I am (and I have a feeling most of you are ), you're already aware that it's critical to get bugs off your paint as soon as possible before they cause any damage to the clear coat.
If you act quick and have Diamondite Bug Eraser handy, bringing out the hose, bucket, wash mitts, and drying towels are not necessary to get those pesky bugs off the front of your car. With Diamondite Bug Eraser, removing bugs is easier and more convenient than ever, all you need is some nice microfiber applicators and microfiber towels. Spray and wipe - it's that simple.
You can clearly see how nasty the bugs are splattered on there.
Diamondite Bug Eraser comes in a ready to use 32oz spray bottle. Simple spray, wait 30 seconds, and agitate with a microfiber applicator.
Once the paint is clean and free of any bugs, spray on the Diamondite Crystal Gloss Surface Protectant to enhance the gloss and add a protective polymer coating that will also aid in future cleaning.
Gently wipe the surface using a clean, dry microfiber towel.
Now the paint is clean and protected. Diamondite Bug Eraser is a quick, safe, effective means of removing stubborn bugs before they cause any harm to your vehicle's delicate finish.
Bug damage avoided and it was really easy!
Now I need to get some Dr. ColorChip for those chips...
Old Apr 29, 2011 | 03:10 PM
kwak12r's Avatar
kwak12r has a spectacular aura aboutkwak12r has a spectacular aura about
is it safe for clear bras?
Old May 2, 2011 | 07:18 AM
It sure is!
Old May 4, 2011 | 07:42 AM
If you need something with a little more "bite" to remove the bugs and tar, check out the Diamondite Bug Eraser Combo. This combo includes the Diamondite Bug Eraser, Safe Scrub Bug & Tar Pad and a Cobra microfiber towel. Spray, lightly scrub, and wipe away the bugs!
Old May 5, 2011 | 04:36 PM
Mike@Vossen's Avatar
Mike@Vossen is a splendid one to beholdMike@Vossen is a splendid one to beholdMike@Vossen is a splendid one to beholdMike@Vossen is a splendid one to beholdMike@Vossen is a splendid one to beholdMike@Vossen is a splendid one to beholdMike@Vossen is a splendid one to behold
Good post! I think I'll pick this up tonight.
Old May 17, 2011 | 07:49 AM
After 5 days of bugs splattering all over the front end and windshield on my car, I came to work a couple minutes early today to clean it up.
After removing the bugs with the Diamondite Bug Eraser and Safe Scrub Bug Sponge, I quickly went over the areas treated with DP Waterless Wash in a Kwazar Spray Bottle. I did this to remove any loose debris and to also ensure a clean surface prior to applying the Optimum Car Wax.
I thoroughly sprayed the front of the car with the Bug Eraser and let it sit for about a minute before scrubbing with the Bug Sponge.
If there is one thing that I cannot stand, it's dirty windows in my car. While the Bug Eraser was doing its thing on the front of my car, I went ahead and cleaned the glass with Diamondite Perfect Vision Glass Cleaner. This is my go to glass cleaner because it contains no ammonia, is safe on tinted windows, and has strong cleaning ability to cut through some of the toughest films with just one pass, all while leaving a streak free finish.
About 10 minutes later, the car is clean and protected.
Now that's perfect vision.
Old May 17, 2011 | 12:39 PM
ConcreteRon's Avatar
ConcreteRon Is a GOD !ConcreteRon Is a GOD !ConcreteRon Is a GOD !ConcreteRon Is a GOD !ConcreteRon Is a GOD !ConcreteRon Is a GOD !ConcreteRon Is a GOD !ConcreteRon Is a GOD !ConcreteRon Is a GOD !ConcreteRon Is a GOD !ConcreteRon Is a GOD !
Nick, Can you use the "Safe Scrub" on a clear bra?
Old May 17, 2011 | 12:43 PM
Yes, just make sure the Safe Scrub is properly lubricated along with the surface while using it. If you really want to play it safe, soak the sponge in hot water for several minutes prior to being used.
COBB Tuning
Mar 29, 2016 09:26 PM
Sep 1, 2015 03:16 PM
