Removing residue from wheel weights
Old Apr 13, 2015 | 07:22 AM
Jonhunt's Avatar
Jonhunt is infamous around these parts
What's the best way to remove the residue from where a balancing weight was? These are OEM 911 wheels. I tried Goof Off, but it doesn't seem to have much effect. Thanks.
Old Apr 13, 2015 | 08:48 AM
cab83_750's Avatar
cab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud of
I noted that you used goof-off
Scrape as with a plastic tool (like door panel remover tool) as much as you can. Then use goof-off.
Yes, been there done that. But goof-off, IMO, I even though slow is still the safest.
Old Apr 13, 2015 | 09:06 AM
Jonhunt's Avatar
Thanks...I'll give that a try.
Old Apr 13, 2015 | 09:19 AM
cab83_750's Avatar
Of course, wash and wax afterwards to eliminate GOOF-off.
Old May 11, 2015 | 03:52 PM
JSF721's Avatar
JSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud of
I have used Wurth Prep Solv and brake cleaner. Make sure to degrease and apply a good sealant or coating afterwards and it will remove all waxes and sealants.
Old May 24, 2015 | 03:38 PM
cmoore1's Avatar
cmoore1 is infamous around these parts
3M General Purpose Adhesive Cleaner 08987 works good
Armytrix_F1_Exhaust
Jul 7, 2019 11:31 PM
RS GT3 RS
Sep 24, 2015 09:27 PM
Sep 1, 2015 03:16 PM
riozilla
Aug 21, 2015 11:34 PM
Fabspeed Motorsport
Audi
Aug 21, 2015 11:30 AM
