How to detail Aston Martin DB9 parcel area
Remove the shelf, no tools required, just a little force, the shelf will 'pop' out from its clips. I would suggest you use new (fir tree) clips when you replace the shelf.
Use a foam cleaner, which should be given dwell time and then gentle agitation with a medium stiff bristled brush to get the product into the materials surface, the low moisture content of foam can then be easily rinsed and the surface dried. Remove excess product and debris with a clean, damp 100% cotton micro fibre towel.
If the foam is allowed to dry the soil will be re-deposited to the surface. Check the results and repeat process as necessary
For heavily soiled areas use a foam cleaner (Leather Master™ Foam Cleaner) that contains a surfactant that will lift dirt and soil, allow react time to do its work and then use a soft brush to agitate and loosen the dirt (Swissvax Leather Brush) especially on light coloured leathers; this enables the cleaning of the micro pores and creases and lifts the dirt out and reveal any further work that needs doing (dye transfer, stains, etc.)
biggynuts01
Sep 1, 2015 03:06 AM
